Question about Samsung Digimax S730 Digital Camera
The lens on the camera is stuck out. When I turn the camera on. It doesn't go past the samsung picture screen i have saved on there. It won't let me go to the menu or anything. It won't let me turn it off, I have to remove the batteries.. Please let me know what I can do.. Thanks!
My scream is on but the lens are stuck and just a couple of second , the camera start a 3 sound and shuts down ... help
me !
Posted on Mar 20, 2008
Our camera seems to be okay but when i'm attempting to get picture, i can't see any image in LCD, is it the lens?
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 13, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
When I turn on my camera, it shows a black screen, so I'll take a picture anyways and its black.. no picture ..is it fixable or should I throw it away? Next to where the flash goes off..there is a...
Is the lens protector opening in the front of the lens???
If it is and things are still black then throw it out... it will cost more then it is worth to fix...
Lens Errorfix for Digital Camera
heatman101
May 26, 2011 | Fuji FinePix F460 Digital Camera
The display will not show anything when the camera is turned on. All the options are on the screen but nothing else. It is black.
First off you didn't say if the pictures it is taking are OK, or if they are also black. If the pictures are turning out fine, then it's likely that you just accidentally pressed the DISP or DISPLAY button on the back of your camera, accidentally turning the screen off to save batteries. Press the button one more time to turn it back on.
But if the pictures take are also black, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Apr 04, 2010 | Canon PowerShot A540 Digital Camera
Lcd screen is black
First of all, make sure that you didn't just accidentally turn the screen off. Press the DISP or DISPLAY button on the back of your camera with the camera turned on. This button manually turns the screen on and off to save batteries.
OK, you already knew about that button. Don't get offended, a lot of people don't. Take a picture with the screen black, and download it to your computer. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Mar 28, 2010 | Canon PowerShot A630 Digital Camera
Mt camera will not show a picture to take the screen is blank when you turn it on
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
If that didn't help, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Lens stuck
First, if you can, try to save the pictures on the camera to something off the camera. Then, on the camera menu, navigate to the RESET menu option and select it. The camera should reset and hopefully it will function properly. If this doesn'r work, then the camera will have to be repaired or replaced.
Jun 13, 2009 | Samsung S1070 Digital Camera
Lens is stuckpartly open power button does nothing-won,t turn off
mine has done this and I have grabbing the lens and pulling it out at the same time as I turn it on. It is a pain but it now works
Jun 24, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax S730 Digital Camera Logo
50 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
