Question about Palm Zire 72 Handheld
ZIRE 72 CAMERA
Whne i go to the camera screen it freezes up and doesnt work
  • 1 more comment
  • Nukuta Apr 20, 2008
    Hi! I have the same problem, in russian forum one guy have solved this by restoring from backup. My back-up has not help. Need a solution!
  • mac_zire72 Apr 29, 2008
    Zire 72 camera does not work. When click on button or use stylus on screen the screen goes blank (white) and stays that way. A reset in the back of the Z72 is the only thing that brings it back. As far as I can tell everything else works fine. This seems to be the result of replacing the battery. Is there anything inside the the unit that may need to be fixed (hardware) or is this a software issue?
  • sotolite Feb 08, 2009
    Hi guys, I have the same problem. Whenever I would attempt to use my zire 72 camera to take photos/videos, it just freezes/hangs. A reset would allow me to use the device again except when opening camera.
    Can this be solved in some sort of a new setting or it has to be opened by a technician?
    Thanks!!!
    sotolite@yahoo.com
I changed the battery in my PDA recently and encountered the same problem. The fix for me was in the camera circuit board cable, the one at the top. For some reason, there is no actual plug for cable to go in, so I thought it just rested as is. The cable must actuly be pulled gently back towards the top of the PDA and then aligned with the contact pins from the circuit board. Again, it doesn't actually plug in to anything, but just rests against the pin connector. Be careful reassembling, because the ribbon cable can pop out of place easily (it essentially becomes "spring loaded" when put in place). Hope this works for you.
Posted on Jun 03, 2008
How to work zeki front camere
whne in camera mode on your screen upper right should be camera outline with circular arrows inside camera diagram you touch that and it switch to front veiw and vis versa.
Dec 08, 2014 | Cameras
I replaced the Battery in my palm Zire 71 and two pieces that fell out and then when i put it back together with out them the camera wont come on at all I have the pieces but I just need to find out w
You aren't going to find that information anywhere. My advice is to either return it to Palm, or buy a spare one. There is one for $4 that needs a charger.
Palm Zire 71 Repair
Palm Zire 71 Take Apart Directions - DirectFix
www.directfix.com/category/_ZIRE71_TAKE.html
iPhone Replacement Parts? We offer iphone parts for cracked iphone screens. DirectFix offers iphone screen replacement parts, iphone repair parts & iphone ...
Palm Repairs ' palmdr.com
www.palmdr.com/pda-repair/palm Tungsten T, T2 and T3 Repair Form. Zire Series Models Zire 72 Choose either our Repair Form or Express Repair Service Zire 31 Repair Form Zire 71, Zire 21, ...
Zire Series : PalmDR.com, PDA Repair Done Right!
www.palmdr.com > Home > Accessories Products 1 - 12 of 27 - PalmDR.com : Zire Series - PDA Units Accessories Printers Repair ... Perfect fit screen protectors for your Palm Zire 71 or Zire 72 PDA unit.
Palm Zire 71 PDA for Parts or Repair • $4.00 - PicClick
https://picclick.com/Palm-Zire-71-PDA-for-Parts-or-Repair-192159832687.html Up for auction is a for Parts or Repair Palm Zire 71 PDA for Parts or Repair This is in excellent physical condition but I do not have the charger 192159832687.
Palm Zire 71 PDA for Parts or Repair 805931008343 ' eBay
www.ebay.com > ... > Gadgets & Other Electronics > PDAs > See more Palm 71
Rating: 4.5 - ‎80 reviews
This is sold as is for parts or repair. This is in excellent physical condition but I do not have the charger to test. I do not know if the battery is good or bad or if it is ...
Palm Zire 71 Blue PDA Organizer - Bad Battery - For Parts/Repair
www.ebay.ca > Consumer Electronics > Gadgets & Other Electronics > PDAs Palm Zire 71 Blue PDA Organizer - Bad Battery - For Parts/Repair in Consumer Electronics, Gadgets & Other Electronics, PDAs ' eBay.
Jul 25, 2017 | Palm Zire 71 Handheld
My PalmOne Zire 72S battery won't charge. How do I
I can't get the back off my 72s to replace the battery, any instructions would be appreciated. One source says there is a third screw in the wire mesh but I only found the 2 lower ones. Also, I can't find the Media Icon anywhere, therefore I can't use the camera or download pics. I even reloaded the software to no avail.
Nov 29, 2009 | Palm Zire 72 Special Edition Handheld
My PalmOne zire 72 screen is frozen on the real player screen and nothing was playing. Empty. I had just tried playing off a mem card. I thought it would read and play card? I'm a tech idiot!
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Now for the link......
http://kb.palm.com/wps/portal/kb/na/zire/72/unlocked/supportservices/page_en.html
Nov 27, 2009 | Palm Zire 72 Special Edition Handheld
How to insert a sim card into my Palm Zire 72
No sim card in the Zire 72. On-board memory on the motherboard only to store records not directed to or on expansion memory card.
Zire 72 battery changeout not designed to be user serviceable. Undertake at your peril (unless you are very steady handed, patient, and very very careful). The 72 is probably the most difficult of the Palms to change batteries. Go to: http://forum.brighthand.com
Navigate to the Zire 72 section and read the posts. There are even detailed photos and uTube movies that deal with changing the battery. I have used their forum for years. Lots of help there.
May 30, 2009 | Palm Zire 72 Handheld
My Palm Zire 72 tumbled into two inches of water.
It seems that unfortunately you PDA is damaged and needs professional repair service, or just forget about it and buy another one.
Water causes to have corrosion and shorts in electronic devices, even if is dried internally (residues cause the shorts), which is an quemical effect of have water (or moisture) with copper and other metals and a voltage from the battery.
If anyway is already damaged, you may want to try in repair it yourself.
If so, you will need to open it, and remove all residues (kind of green or white dust over the components) from the copper traces, connectors and components.
If the event is recent, there is the chance you can clean it completely, but I do see that this happened a couple of months ago.
If several weeks (or months) passed, then a deep corrosion already took place in it, and is likely that the components and connections have been permanently damaged.
In order to open and repair, you will need:
1. Torx scredriver and philips screwdriver
2. Plastic pry tool to open it without leave marks or damage the PDA housing
3. 5X magnifier with light, or better if you can use a microscope, so you can review all the areas (including under the tiny electronic components) and clean them.
If you send it to repair, it will be expensive, and it may be over the cost of buy an used PDA but in good working conditions.
I mean, depending of the damage caused by the water, it may be necessary to replace one or all the major components inside the PDA (mainboard, LCD screen, speaker, camera, battery, etc).
Best regards,
May 25, 2009 | Palm Zire 72 Handheld
Ready to change battery in zire 72s
Here is a video I found on replacing the Zire 72 battery. I hope this
helps.
Mar 26, 2009 | Palm Zire 72 Handheld
Zire 72
On your disk, go to the post install folder and run the outlookswitcher.exe, this will let you switch to the outlook conduit
Jan 30, 2009 | Palm Zire 72 Handheld
Palm Zire 72
You have a bad connection, or no connection to the digitizer. This is common when changing out batteries. Re-open the case and check the connector to the digitizer.
Nov 01, 2008 | Palm Zire 72 Handheld
Zire 72 does not recognize the SD card
Have you used this card long and what size is it?
Jul 11, 2007 | Palm Zire 72 Handheld
Palm Zire 72 Handheld Logo
146 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
