Question about Philips Televison & Video
Phillips plasma 50 inch HDMI cable port being blocked by cable Cable company will not do anything. Cable box explorer 8300hdc It will run for a day or two then the cable port stops working.
  • 3 Answers
There are some ambiguities in the HDCP protocol (rights protection for HD).  When two devices use this one will send a message to the other, it then waits for a response, lastly it responds back.  This is the connection setup procedure.  The issue is that there wasn't a specified time limit that a device must wait before assuming the connection isn't working.  This can cause you to get an error message along the lines of "your tv doesn't support hdcp"  Unfortunately, there's not much that can be done about this.  I spent the better part of two weeks researching this issue with my own television and cable box.  I actually called the cable company and the contractor they use to link them to all of the relevant information but they still insist my tv has an issue.
On the other hand, if you're not getting a message like this you may need to clarify whether you are getting an error or if it's just completely blank.
Posted on Mar 04, 2009
I have a hitachi p50h401 and sound went out. someone said update software how do you do that? Thank You
well if the sound went out it may have only effected 1 output source, What type source are you using, HDMI, RCA, Composite, DVI, VGA with mini adapter? If for example the HDMI, port you are using has simply lost sound to that port, HDMI carries both sound and video so simply moving to HDMI 2 or even 3 may solve this issue. Also i would suspect the cable you are using, HDMI cables are often defective. If you are using coax thru your cable company i would also change that coax from your tv to the hd box.
May 28, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I am trying to connect my lg 50'' plasma trying to my lenovo through vga to hdmi cable ,but am not geting display on lcd.
from a cable box you must have the box in hdmi mode turn cable box off with tv on and press menu on cable box remotly scroll down and turn on HDMI
Nov 18, 2009 | LG 50PX5D 50 in. Plasma HDTV
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: http://www.scientificatlanta.com/products/consumers/new_cableboxes.ht64. Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
Convert 480i to 720p
Turn off cable box.
Turn on TV.
Hold down media and guide for a few seconds.
On TV pick the resolution you want. Your choices are 480i, 480p, 720p, some wide screen resolutions and 1080i.
Save the results.
You should be good to go.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
HDMI Support
Follow this link dowload the software upgrade for your tv and procced to install this can help to solve the problem
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=50PF7320A/37&scy=US&slg=AEN&searchtxt=50PF7320A
Your rating to my answer is highly appreciate
Thanks
Jun 29, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Maxent MX50X3 HDMI input
I had the same problem and found that the ground wire outside where the cable companys box is was not even hooked up. It was just hanging there, once I hooked it up it went away. The cable company gave me the run around telling me it wasn't their fault. I now have Direct Tv.
Dec 04, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Philips 50 inch Plasma - no audio on occasion
Try swapping the HDMI cable. They occassionally fail.
Nov 21, 2007 | Philips 50PF9630A 50 in. Plasma Television
Televison & Video Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
