Canon copier Error Code 300 Model #: F188600 Serial #: KAB23899
  • david717 Mar 13, 2008
    Canon copier Error Code E000 (correction not Code 300)
  • 19,396 Answers
E000 means the heater lamp in fixing unit is faulty (probably blown). It is not a difficult operation, however, if you do not have practice servicing the machine, it may require a qualified technician to fit a new one.
Here is a reseller for usa that delivers worldwide.
regards
Posted on Mar 13, 2008
  • Ginko
    Ginko Mar 13, 2008
    Here is same solution for same problem on a similar model.
    e000 on canon copier is a heating problem, sometimes it just fixex itself resetting the machine. Try hard reset disconnecting from power outlet 20 minutes, and then try reset procedure from manual. If all this does not work, then generally it is the heater orjust the termistore to be changed.
    Here is resetting procedure for canon d880:
    Press "Additional
    Functions", press "#", then press the "Right Arrow" button till it
    says, "Printer", then press "Set" then press the "Right Arrow" button
    again until it says "Printer Reset" then press "Set" again, the display
    will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then
    press "Set". Now, unplug the power cord and wait 5 seconds and plug
    back in. If this don't work, get a new fuser.
    Here is canon customer service troubleshooting page.
    regards
    Guru:
  • 1,894 Answers
Solution:
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser.
  • 2 more comments
  • dewan nafees ahmed Mar 13, 2008
    that is what i was also seeing..
    error 300 is a http error sent back by routers...
    lols..
    http://smarka.com/members/boards/content...
    this forum will help for sure
    for igbt: ur 1st comment as a solution was really good: :)
    E000, E001, E002, E003 CODES
    To reset these codes perform the following:
    Remove the front panel and be careful not to bend or break the flexible
    cable connected to the panel and the DC Controller.
    Turn on the copier and short the jumper wires JP3 and JP4 on the dc
    controller pcb with a screwdriver.
    The count ratio indicator on the control panel turns on 'F'. When 'F'
    is turned on stop shorting the jumper wires
    Turn off copier and turn it back on and its then reset.
    reference for my last post is this site
    the last post is common for all the canon copiers.
    good luck
    thank you
    have a good day
    for IB4G2008: ur 1st comment as a solution was really good: :)
    Genius:
  • 3,587 Answers
Ok..let's see how that translates..
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Mar 13, 2008
    what's the model number on the front of the machine
  • Patrick Michaels
    thanks..wondered about that..
  • Patrick Michaels
    A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
    The error can be cleared in the service mode.
    Contact Canon Consumer Products 800-828-4040
I would like to know what Error300 means on a Canon Super G3.
there is no error 300 on this model
g3 is a fax standard---all current fax machines on the market are G3 not a machine model
Jan 12, 2015 | Canon imageCLASS D-480 - 23 PPM...
E000719-0031 error code for canon ir c5250
E719 0031 00 Title Error in serial communication at the start of the New Card
Reader
Description Failure in communication with the serial New Card
Reader at start-up.
Remedy - Check if the cable of the serial New Card Reader is
disconnected.
- Take out the serial New Card Reader.
- COPIER > Function > CLEAR > CARD
- COPIER > Function > CLEAR > ERR
Dec 20, 2013 | Canon Office Equipment & Supplies
E00748-4000 error on canon irc3180 copier
Try this Board Cleaning & re-Positioning Procedure
Works 98% of the time for this e748-4000
your model is in same family as those listed in pub
or----------------------
Check or swap or replace the DDI-S Serial Cable before replacing any boards.
If the cable is poorly connected or otherwise defective an error code of E748-4000 may be the result.
Sep 01, 2011 | Canon iRC3100 Printer
I have problem canon ir 5000 e355,,....please help me
How to clear the error code:
1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
3. Under the [FUNCTION] tab, select the [CLEAR] option.
4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
5. Reboot the machine.
If the error occurs again:
1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
2. Reseat the Main-Controller board into its slot.
3. Go into service mode and clear the error code as explained above.
* If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
Aug 27, 2010 | Canon imageRUNNER 5000 Copier
IR 1210 Error cod E245
how to reset the system Err E245 in canon Ir 1210
Jul 20, 2010 | Canon imageRUNNER 1210 Copier
Error code 354-0002 ir7200 serial number pcb
when you changed the main controller for the copier did you use the counter board that was on the old main controller or did you put the counter board from the old one on the new one.... if you don't use the old counter board with the new main controller then that problem will occure
May 19, 2010 | Canon imageRUNNER 7200 Copier
Canon Pixma MP780 gives no lights no response
There are no error code #300 to look up. Please check the error code again and repost and I'll try to help you out with this problem. However the is a #300 error for the fax, it's basically a wrong number was dialed.
You can get the Manual from Canon's website. www.usa.canon.com
Nov 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
Error Code E000350-0001
It is a fault with the serial number PCB..
Suggest you get a tech to fix this one.
Jan 18, 2008 | Canon ImageRUNNER 3570 Copier/Printer
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
