Question about Toshiba Tecra 8100 Notebook
Blank screen when i turn on my screen just blank and i can't enter to set bios by presseing f2.thank your help. tommy
  • deeprash2 Mar 28, 2008
    hi i have the toshiba tecra 8100. when i press the power button the blank screen appear on my screen but the large time i tries to start this it will start for a short time. i m not able to understand the problem, sometimes it gives the message bios has been damaged. pls call the service man.
  • Devocap
    Devocap May 11, 2010
    Have you tried pressing Fn + F5? This hot key will cycle you through the display options. Also are you getting any indications of power to the system, such as blinking lights or beeps? If so, what are they?(full description required)
    Problem Solver:
  • 5 Answers
COuld be a simple case of the screen catch hole where the lid locks shut getting stuck (fluff ?) jab it a few times with a paperclip. Worked wonders on an old tecra I had. If it is not this it may well be the inverter which needs changing - this is a kind of starter / voltage regulator fot the FL tube.
Posted on Mar 15, 2008
HOW TO UNLOCK DELL LATITUDE E6420 PASSWORD = 1D3B
Contact Dell, prove ownership and they may be able to help.
Feb 26, 2015 | Dell Latitude E6420 14 Notebook Core i5...
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Toshiba lap top - satellite - when i turn it on it brings up a black screen with red writing - saying TOSHIBA and under that it says press F2 for boot selection - pressing f2 does nothing - if i hold
try pressing the F2 key during the boot process to enter set up (bios)
using the arrow keys navigate to advanced bios features press enter make sure its set to boot from your hard drive
press F10 to save to cmos restart
hope the helps
Oct 06, 2012 | Toshiba Satellite Computers & Internet
How can i set up defaut values on my packard bell laptop
Enter the BIOS configuration, pressing F2, F10, F1 or DEL at boot. At the BIOS screen, go through the pages, there will be an option to set everything to optimized defaults, save and reboot.
Sep 08, 2011 | Intel Packard Bell R4360 Notebook
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Computers & Internet
How do i reset my laptops cmos battery i have a dell inspirion 5100
The Basic Input Output System (BIOS) on a Dell laptop is used to help hardware communicate with the operating system. You can change many different aspects of your Dell laptop's BIOS such as boot order, BIOS time, set a system password, and change certain aspects of how your hardware works. If you want to reset your Dell laptop BIOS to its original settings, you can do so by changing only one setting. This setting restores your BIOS to its default settings, no matter what settings you may have changed.
1. Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart." 2. Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2." 3. Use the "Alt" + "F" key combination to load defaults. 4. Press "Esc" on your Dell laptop keyboard to save and exit. 5. Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
I hope that these steps help you.
Please rate me.
Thanks.
Aug 09, 2011 | Dell Computers & Internet
I had lost my Dell Latitude D600 Bios passowrd. So I removed the comos battery (behind main battery) and reinstalled it. But now my laptop is giving this message on bootup "invalid system...
  1. Set the BIOS to defaults:
  2. Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
  3. Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
  4. Use the "Alt" + "F" key combination to load defaults.
  5. Press "Esc" on your Dell laptop keyboard to save and exit.
  6. Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 22, 2011 | Computers & Internet
How to reset bios my dell vostro 1500 . (11R50G1-595B)
To reset the BIOS please follow the below steps.
1 . Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
2 . Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
3 . Use the "Alt" + "F" key combination to load defaults.
4 . Press "Esc" on your Dell laptop keyboard to save and exit.
5 . Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
Thanks. Have a great day.
Dec 30, 2010 | Dell Vostro 1500 Notebook
Compaq screen goes blank after power up?
When yo upower up press F! or F2 or "del" key to enter in bios then check your harddisk is detected? if your harddisk is sata then enable sata option in bios then save settings.
If every thing is fine then it should be dispaly resolution issue.
When yo upower up vthe computer press F8 key then enter in enable vga mode then go to control panel then dispaly proeprty-> settings ->change screen resolution to 1024*768 then restart .
Thanks for using fixya.
Please rate this solution if it helps you.
Jul 27, 2009 | Acer 91.63X07.001 Keyboard
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
Toshiba Tecra 8100 Notebook Logo
133 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
