Question about HP PSC 1210 All-In-One InkJet Printer
HP psc 1315v noise
My printer works well, but is making terrible noises when scanning. Is there a way to clean it or oil it or something??
Thanks for any advice!
    Sergeant:
    Champion:
  • 210 Answers
there is no way to oil it. u can clean the scan glass, rollers etc with a lint free cloth. check for any paper stuck inside.
if it is still making grinding noices, you may have to service the unit.
thanks and regards
agnel
Posted on Mar 18, 2008
Will not feed paper.
Open the front door, take cover behind the printer a little can shake up to something it's a pen
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
HP 1610 first was making a terrible noise when it picked up paper now it doesn't pick up paper at all and keeps showing paper jam, anyone have a solution? I really liked it when it worked
verify that there is not any paper jammed and check the back of the printer if you are sure there isnt ..then the waste assembly needs to be cleaned of waste ink build up... the assy is located on the right side of the printer under the inks
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | HP PSC 1610 All-In-One InkJet Printer
My HP1110 started making terrible banging noises but worked OK, then I had to change the ink cartridges, now it won't print at all. Please help. Thank you Marion
open the printer cartridge bay, remove the 2 heads the color and black, wipe the contact points that are connected to the head and the printer with clean tissue with alcohol... Snap and release the cartridge and test it if it works
Oct 21, 2009 | HP PSC 1110 All-In-One Thermal Printer
I have HP PSc 1210 all in one printer. It does not load the paper. It makes grinding noise as it is trying to load it. But does not work. Any help will be appreciated.
the noise is coming at the time of cleaning the cartridge.you can remve the printer top cover and right side of the printer you can see the waste ink pad .clean the pad and cartidge cleaning pad. put some grease in the cartrige cleaning pad moving unit area.
Sep 25, 2009 | HP PSC 1210 All-In-One InkJet Printer
My HP laserjet 1200 is making a terrible noise when printing - do you have to oil the rollers?
No Please don't oil any part of the printer, oiling may damage the complete printer first check if the nopise is coming from rear, Top, Front or side.
If noise is coming from Top than possibly top outbin roller are making noise.
If side tham may be toner cartridge or cartridge motor is making.
If noise is coming from rear than either fuser or the gear which rotates the fuser are making noise.
If noise is coming from from than Tray 2 pickup assembly or faulty tray is making noise possibly faulty registration assembly can also mak noise none of the part should be oiled only the faulty part should be replaced.
May 11, 2009 | HP LaserJet 1200 Printer
Noise when beginning to print or copy
Mine always makes noise too, I don't know why. But I know that it's a lot noisier when paper quality is set for draft, so you might want to check that.
If you just go into the printer properties, under the tab that's something like Paper/Quality. There will be a drop-down list where you can choose the quality of your print out, i.e. Best, Normal, Draft or FastDraft. If it's set for Draft, you might want to change it to Normal. Draft uses less ink, but it also doesn't come out quite as clear, and is very loud.
Mar 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
We have a HP printer series 1310 and have recently purchased an ASUS notebook. We have attempted to install this printer to the laptop with difficulty as we continually rec've an error msg stating it is...
Hello
The printer should be compatible with both vista and XP
your printer is a serie 1310 but if you look closer you should find a more exakt nr like
» HP PSC 1311 All-in-One Printer
» HP PSC 1312 All-in-One Printer
» HP PSC 1315 All-in-One Printer
» HP PSC 1315v All-in-One Printer
» HP PSC 1315xi All-in-One Printer
» HP PSC 1317 All-in-One Printer
» HP PSC 1318 All-in-One Printer
or something like it. check for the serie nr or a mark somewere on the printer and you should find the right printer model.
you can download the drivers here when you find the right model.
good luck.
hope I helped.
Sep 04, 2008 | HP Computers & Internet
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
