Question about InFocus LP290 1100 Lumen XGA LCD Projector Multimedia Projector
InFocus LP725 I have an older InFocus LP725. When I turn it on, I just get a garbled inage on the screen. Is there a reset button on the machine? it is as if the image froze and garbled. I cannot bring up the onscreen projector menu or cause it to change the image in any way. Thanks.
Hi i have the same projector and the light lights up and i can hear the video display music but screen stays blank just the white light on the wall what is wrong?
Posted on Jun 29, 2008
  • 563 Answers
Hi there
Resetting the unit will unfortunatelly not work , you are facing replacing or repairing the Projector's Mainboard.
Quite expensive to do
Posted on Apr 01, 2008
SOURCE:
How to factory reset akai ds8341 camera. I see garbled images on the 2.5 inch lcd monitor
Two ways... 1. Go into the camera menu and find "reset"...follow the on-screen instructions. 2.Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 23, 2009 | Akai DC6371 Digital Camera
InFocus ScreenPlay Projection HDTV does not turn on
try accessing the service menu and doing a factory reset on it
Jul 30, 2009 | InFocus ScreenPlay 61" Rear Projection...
PS3 having problems
try resetting the display (although I don't know if this will help you but worth a shot), press and hold down the power button on the front of the machine until you hear 2 beeps.
Also make sure that all your leads are pushed in fully and you have nothing within range that can distort your picture. (for example if my son uses his remote control car my screen goes flickered, if my neighbour turns on their mower same garbled screen again)
I hope this helps
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
DVR633H timer recording screen inaccessible
I had the same problem. Contacted Pioneer tech support, they had me send the machine in even though it was out of warranty; apparently a hard drive problem that they were researching. They sent it back with HDD replaced, worked again.
Sep 08, 2008 | Pioneer DVR-633H-S
Infocus lp 530
Hello, That should absolutely reset the lamp timer.
This is crucial: Press and hold the volume - button, then press the source button (while still holding down the volume - button) for 5 seconds.
Make Sure you hold them both down for 5 Seconds!
I hope this helps you.
Cheers
May 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
Infocus LP350 won't show signal, also panel buttons don't light up
Hi LuckyLindy
Next time this happens , just take out the main connection to the Mainboard and plug it back in.
Also remember to reset your lamp timer now that you have replaced the lamp !
Apr 24, 2008 | InFocus LP350 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Infocus LP725 projector
May 25, 2007 | InFocus LP725 and LP735 Replacement...
219 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
