Question about Pioneer AVH-P6500DVD Car DVD Player
Faceplate avh-6500 vs avh 7500
Hi! i lost my faceplate for my avh-6500, i found one but is for the model avh-7500, do you think is fit?
thanks.
Phil
  • avinesh Mar 16, 2008
    will 7500 work on 6500
  • Mayquel Jun 01, 2008
    Missing the face plate where can I find one.
Pioneer electronics website has the avh-p6500 face for 119.00
Posted on Apr 23, 2008
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
Lookin for a pioneer Avh--p6400cd faceplate
http://tigerdirect.partsearch.com/Model/Pioneer+Electronics/Pioneer/AVHP6400CD.aspx
Nov 12, 2009 | Pioneer AVH-P6400CD Car DVD Player
Pioneer avh-p7500 switch live
i dont know too much about these, but what i do know is, most of these units have a small 1 amp continuous blow glass fuse inside the unit, i would have a look to see if yours has it, and also look for any signs of over-heating on the PCB
Aug 13, 2009 | Pioneer AVH-P7500 Car DVD Player
No pics on avh-p4000
Right after I send my problem with my p4000, I found what's where wrong... I forgot the little black wire ground. I simply put wires togheter (the big on and the small) and now, it works !!! I can see pictures and sound from DVD and listen music with USB flash drive...
Hope this will help you...
Phil
Jun 13, 2009 | Pioneer AVH-P4000DVD Monitor
Have a pioneer avh-p6500dvd want to upgrade a new brain can I
Hi. I believe you you can as long as the connector for the data cable is the same on the brain that you want to upgrade to. Good luck.
Jan 21, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Horsepower
I've found two different hp ratings for the VS800: 50 hp at 7500 rpm (according to suzukicycles.org) and 60hp at 6500 rpm (according to bikez.com).
Nov 10, 2008 | 2004 Suzuki VS 800 Intruder
Can I use avh-p6500dvd radio with avh-p6600dvd brain.
i do not no the answer to your question but i have the brain for the 6500. if you interested email me and i will sell it to you. thanks corey
tomcat613@cox.net
Oct 04, 2008 | Pioneer AVH-P6500DVD Car DVD Player
FACE
You can take a piece of tape or a small peice of paper (matchbook anything) and pin back the little tab in the middle towards the bottom that is pressed when you put the faceplate on or goto circuit city and steal one off the floor model i had the same prob gl
Jul 07, 2008 | Pioneer AVH-5700DVD Car DVD Player
Detaching faceplate on dual stereo XD 7500
Got to the following lik for your manual: http://www.dualav.com/i/product/manual/xd7500.pdf Refrence page 6 for instructions. With the unit off, press open to allow the front panel to slide down. Genetly squeeze the release tab located on the bottom center underside and pull faceplate down and away from unit to remove. To install insert left side faceplate first then push right side to secure. Hope this Helps L8R
Sep 18, 2007 | Dual XD-7500 CD Player
Alpine CDE 9881
You must have a faceplate from that exact model, no others will work. You can try to contact Alpine for a replacement. If it is any consolation, someone has a useless faceplate, because it won't work with anything else, either. Try running an ad in your local lost & found column, you just might get lucky, especially if you offer a reward.
Jul 28, 2007 | Alpine CDE-9881 CD Player
Pioneer AVH-P6500DVD Car DVD Player Logo
578 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
