WORKS INTERMITTING/LOSS OF POWER
I HAVE A 58 IN PROJECTION TV IT WILL PLAY AND WORK PERFECT FOR ABOUT 20 MINUTES AND THEN IT SHUTS DOWN SOME TIMES IT WILL WORK ALL DAY AND THEN IT WILL SHUT DOWN
MODEL#SD582HD5/PIONEER/
  • SEILER565 Mar 13, 2008
    SHOULD THIS TV HAVE SOMETHING LIKE A FAN TO KEEP IT COOL AND IF SO WHERE IS IT LOCATED
    Guru:
  • 1,894 Answers
OTHERWISE- THIS SET MAY HAVE THE DREADED 1500UF POWER CAPACITOR ISSUE WHICH ARE EASY TO SEE IF YOU CAN ACCESS THE MAIN POWER PC AND VISUALLY CHECK FOR 'POPPED' CAPACITORS ON THAT PC
Posted on Mar 13, 2008
  • 1 more comment
  • dewan nafees ahmed Mar 13, 2008
    From the brief description of your problem it sounds like you have a
    component in your unit which is overheating after a short time and
    shorting out causing the set to shut down. It could be anything. If you
    are not a tech you will need to find a reputable repair shop. I doubt
    you could find this, most techs will have problems with this one. Cost
    should not be that much. The biggest problem will be finding the
    problem.
    so i gave one of them in last post that can be isolated.
    thank you
    Good luck.
    If it stays on for several minutes, maybe even 30 minutes or so,
    then goes off, bad solder connections might be the culprit. A modest
    whack or bump on the side or back of set might confirm this. Whack
    it... if set dies, you likely have a bad connection problem. If you
    have good eyes, a solder iron and solder, and know how to solder, then
    you might be able to find the bad connection(s) on the chassis. Common
    locations for this are in the horizontal deflection, power supply or
    vertical deflection portions of the circuit.
    solution was taken from one of the discussions of fixya.
    tough its sounds similar to previous posts it is slightly different. may be it will help.
    thank you
    good luck
    i dont think it has fans.
    but am not sure of it.
    but it will have heat dispensers surely.
    Genius:
  • 3,587 Answers
Thermal sensor is working fine..now, what's the reason?
  • Patrick Michaels
    Patrick Michaels Mar 13, 2008
    a few things..how old is machine..how much air room is in back? anything clogging the air flow inside box
    sounds just like a thermal overload issue, that due to sometimes good, other bad...could be early warning of major issues.
  • Patrick Michaels
    well..usually it's not an issue, but depending on your location, heating in room, etc, a fan can be helpful for any large heat source electronics. The fact that it's not included, is due to design, esthetics trade offs.
    btw, I don't recommend whacking any electronics device.
Toshiba 20vl14 power loss
problem with power supply ask technician check it...
May 04, 2008 | Toshiba 20VL14 20 in. EDTV-Ready LCD...
WHAT CAUSES THE LOSS OF PICTURE AFTER THE TV HAS BEEN ON FOR ABOUT 20 MINUTES.
Power supply board or the inverter board are where I would start. My first guess is over heating of a board so it shuts down. Check the cooling system as well.
Jun 03, 2015 | Televison & Video
Wd60636
Never really had that issue the one I worked on Operated normally for 20 minutes and then shut down completely. The fix for that is to get the OEM bulb instead of the replacement
Jul 08, 2014 | Mitsubishi WD-60638 DLP TV
Tv wrks for 20 minutes, the the picture and sound shuts down
try cooling down tv with a fan to see if it stays on longer. if so, it's overheating. then to next step. feel for excess heat and look for dark areas on components inside. it may be obvious. if not, you may need to call a pro or replace the set. best buy use to do basic diagnostics for $25, but that was about 7 years ago
Nov 25, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Our Sony KV36FV16 works perfectly for 5 min. then powers off.
After speaking to a local TV repairman, the concern of labor and unavailability of parts, led us to purchase a new TV!
Dec 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Tv coms on a few mun. then shuts down
Rear projection televisions are old technology. It is probably overheating. Check the cooling fans.
Time to upgrade to a Ultra HD 4K Flatscreen.
Mar 07, 2018 | Pioneer SD-P50A3Q 50" Rear Projection...
Powers off intermitantly
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
