Question about HP Pavilion dv6000z Notebook
CD drive not displaying in windows explorer
The DVD rom drive cannot be found/seen in My Computer. When disk is inserted it will also not play. It shows in my devices but has the yellow markers next to it saying the the drivers are installed but the device cannot be found. Almost as though the drive was unplugged. And ideas?
  • Anonymous Mar 15, 2008
    this is working now - i actually reinstalled windows XP and this seems to have done the job but now i can't seem to get the USB to work. Much like the CD drive it is device manager with a yellow marker and none of the sockets seem to work? What's the best route to get this working?
    Once i do that it comes up still saying that unable to find the driver for it - is there any thing else i can do?
    Genius:
  • 3,587 Answers
Sure..sounds like you may need a new set of drivers.
uninstall the cd from device manager, after getting new drivers from cd maker's site or computer makers site.
Posted on Mar 13, 2008
SOURCE:
HOW TO EJECT A DISC IN LENOVO IDEAPAD 330
Sarthak Sharma and Carla Bunis want more answers
there are many ways to EJECT
1: the botton on the try , is marked EJECT
do so>>
2: the tiny hole on front of same tray use unbent paper clip, stuffed in hole and try ejects manually.even drive chassis in hand. by self.
3: windows is this ,not stated,but windows explorer
right click the DRIVE D:>? and click REJECT.
4: in windows, make sure the device manager does not list, the DVD as dead,red/yellow or unknown.
if device manager shows the drive missing or bad you need to get the new driver for it.
so right click the drive (be online) and click update drive.
no full model number stated, 330 is not full. number. so says Lenovo.
btw even a empty tray will eject.
if the disk is cracked or label fell , then only way
2 might work and cleaning the jam by HAND.
if way 2 fails.
only total dismantling the DVD drive can fix it.
true jams are hard work. ok?> physical world deal there.
not one poster here said, the button is dead.
saving this post from going to ALL wAYS it can fail and long.
Sep 10, 2018 | Lenovo IdeaPad Computers & Internet
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
Can i knw whether windows 7 os can be installed in XNOTE RD 400 laptop
Well, if you have a CD-ROM or a DVD-ROM drive, You can insert a Windows 7 installation disk and install it. If not, you can insert the disk in another computer and copy all files in a pen-drive. <You have to right click on the disc folder and select explore to do so.> Then, insert the pen-drive into your laptop and double click the setup file to install Win7 on your laptop!!
Jun 27, 2012 | Computers & Internet
I put either a dvd or cd in the drive and get a message " insert disk in drive
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 03, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
My laptop says I don't have a DVD burner but I do. How can I reinstall it?
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
if your computer came with a disc the drivers could be on it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
dont forget to vote
Feb 19, 2011 | Computers & Internet
Media center does not play cds or dvds please help
You have to check your CD/DVD Rom to make sure the device is not faulty.
Open your Windows Explorer, insert any CD/DVD to see whether your CD/DVD is able to read the the disk.
If it cannot read the disk, most probably the CD/DVD rom is faulty and you have to replace it.
Aug 17, 2010 | Microsoft Windows XP Media Center Edition...
I HAVE A PORTRAIT CD IT SAYS TO INSERT THE CD-ROM
Click on the start menu in the lower left corner of your display.
Click on "My Computer".
A window similar to this one will open and you will see your CD/DVD drive.
If double clicking the drive does not open the CD, right-click the symbol with your mouse and choose "Play" or "Open".
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 16, 2009 | Computers & Internet
When Palying a CD Music skips (Media Player)
Greetings my friend, regarding on your problem try to check or clean your CD/DVD ROM. Try to clean it with disk cleaner cause sometimes we forgot to cleam the important part of CD/DVD ROM its eye the one that reads all the dat in the disk. So try to clean it and play the disk again after you clean. Also try to clean also the disk you want to insert in your CD/DVD ROM in order to prevent this problem again.
Jun 16, 2009 | Computers & Internet
Please insert a disk into drive
You can only copy files to a blank disk by using programs like NERO or by using a re-writeable disk like DVD-RW which you can format and use it like a hard drive. You need also burner not an ordinary DVD or CD player.
Aug 07, 2008 | Computers & Internet
CD/DVD drive stopped working gradually
  1. Ensure the Drive is seen in MY Computer
  2. Try removing the upper and lower filters per this article: http://support.microsoft.com/kb/314060
If the drive is seen in BIOS and in MY COMPUTER, but will not read any media after running the microsoft fix and rebooting, then replace the drive.
Jul 06, 2008 | Dell Inspiron 4000 Notebook
HP Pavilion dv6000z Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
