Question about Sharp AR-M350N Copier
WHAT DOES THE CODE BELOW MEAN
H5-01 IS THE CODE GIVEN ON A SHARP AR M 350N+
  • gunnyt Mar 16, 2008
    I do appreciate that, is there a way to clear that code or do I have to call for service. That was very helpful
  • 24 Answers
H5-01 means the machine has had a jam in the same place 5 times in a row.
Posted on Mar 15, 2008
  • John Edwards Mar 19, 2008
    type in P * C * ( * = star key).
    the machine will go into diagnostic simulation mode.
    type in 14 then press the green copy key.
    the machine should reboot and hopefully now works.
    let me know how you get on
I got this from https://community.spiceworks.com/how_to/11039-error-code-h5-01 try it if it helps.
H5-01 means repeated paper jams on the Sharp photocopiers.
Once the paper jam is cleared properly, you need to clear the error condition.
Put it in 'Copy' mode
Press on the keypad:
P * C * 14
Click execute and press 'Yes'
Then press the 'Copy' tab.
This will reset the menu and jam condition.
Posted on Aug 25, 2015
I need a printer software to enable me print with my window 7 software
To help you install printer software for Sharp AR-M207, please find the link given below and find the topic mentioned as 'Software' and select Windows xp:
http://www.sharp-cee.com/cps/rde/xchg/scee/hs.xsl/-/html/product_details.htm?product=ARM207
GuruAid.com
Mar 31, 2016 | Sharp Used AR-M207 Copier Printer Scanner
My sharp AR-163 shows a E1 error. First the E is flickering and after that the 1 is flickering.
you would need to supply the sub-code that is given by pressing the copy button (big green button)
but it seems that one of the boards has an issue, and would most likely need to be replaced
Oct 10, 2014 | Sharp AR 163 Copier
Sharp mx 350n code e7 90
You need to make sure the machine is in Copy Mode then hit
Pound, Star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jun 29, 2014 | Sharp AR-M450N Black & White Copier
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Ihave sharp Ar - 287 printer the problem in it appear this message call for service . code : E7-11
E7-11 = Shading Trouble
As part of it's calibration process the copier measures the light given off from the copy lamp by its reflection from a white strip under the glass. If the copy lamp has failed this will also give this code.
With the power off and the machine unplugged try cleaning the mirrors and the white strip under the glass. It is sometimes possible to fit the glass upside down so it's worth checking that the white strip is facing down.
This code will normally reset by powering off/on.
Hope this helps
Feb 07, 2011 | Sharp AR-235 Copier
Sharp AR-405 error code F1-15
Hello sir; this error code means " elevator motor "problem inside the finisher,check it out is something stuck the motor. or you have to replace one.
Feb 16, 2009 | Sharp AR-M205 Copier
Connecting Sharp AR M-350N to Wireless Network
ping the IP address if the request times out check your cables , try anothere port in router repalce router
Feb 07, 2009 | Sharp Office Equipment & Supplies
SHARP AR 651 SERVICE CALL
what is code nomber please send me
Jan 13, 2009 | Sharp AR-651 Copier
Sharp AR-M350N Copier Logo
748 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
