THE HOME SYSTEM IS Pioneer HX HTD340
ITS A Pioneer HX HTD-340. WHEN I PLUG IT IN THE TIMER BUTTON STARTS BLINKING. I PUSH THE POWER BUTTON THEN THE TIMER BUTTON STOPS BLINKING AND START AGAIN. THERES NO AUDIO OR VIDEO COMING FROM IT. BASICLY IT DOESNT POWER ON. CAN U HELP?
I had the same problem and is not that hard...maybe the only difference is that i have a xv-ev7 pioneer home theater, but this probably is gonna work for ya. So, when the timer is blinking wait for a few seconds and then turn it on and inmediatly push the timer button. that should work. if not, grab a hammer and...well u know!!
Posted on Dec 31, 2008
    Scholar:
  • 48 Answers
I'm sorry i dont think i can be specific enough on this problem to help,
the only hting that occurs to me straight away (assuming its not actually a faulty system), is that the tuner and timer need to be set up. the instructions for this should be in the manual, also i dont know for sure, but check on the back of the unit to see if a back up battery is required to store settings.
alternatively it shounds like an IC programming problem where for some reason an EEPROM on the IC has dumped its program and it it needs to be reprogrammed, there is probably no way to get that fixed without going back to the shop.
one final possibility is that you should disconnect the inputs and outputs and power it up and see if the problem is reproduced. reconnect them one at a time and power up again.
there is a possibility that an input is either connected incorrectly and giving the sytem a overload and causing it to shut down or an output has a short circuit that when the system is powedred up the current drain is pulling it down. so if its an out put check for daaged cbles. if its an input say audio sources such as TV HDTV the cable is wrong.
hope the troubleshooting tips help you out.
Posted on Mar 14, 2008
My home dvd/cd receiver has pt fan error
you must repair it.
please inspect if fans comes up with power on.
sometimes feedback wire loose connected.
or circuit inside the fan malfunctioning.
better thing is replace.
Jun 28, 2014 | Pioneer HTD-510 System
Dvd and cd wont play on my pioneer htd-540dv system
What happens when you try to play a disk? For more assistance, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
Aug 19, 2013 | Pioneer HTD-540DV System
How can i increase the bass on pioneer htd-510 without remote
I have tried many different ways gave up don't think you can BUY A REMOTE I DID
Aug 19, 2012 | Pioneer HTD-510 System
On a pioneer xv-dv8 home theatre timer light flashes and the unit will not switch on.
I found the manual here:
http://www.pioneer-latin.com/downloads/xrb3033a.pdf
This their recommendation for your exact symptom:
Timer indicator is blinking and the system will not switch on.
• Unplug the system, then plug back in. Wait for one minute then switch on.
• Make sure the fan at the rear of the system unit is not being blocked.
• Check that the speakers are connected correctly.
• Make sure the voltage of the mains power source is correct for the model.
• If the problem persists, take it to your nearest Pioneer authorized service center or your dealer for servicing.
Jan 07, 2011 | Pioneer Audio Players & Recorders
I am trying to find a manual for a pioneer HTD-540DV dvd/cd receiver system. Could you point me in the right direction?
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/HomeTheaterSystems/ci.HTD-540DV.Support
This is the support page for your stereo.There's a toll free # and E-mail help on the right side of the page too.Manuals are available on the web for a price ! I'd just contact Pioneer.
Jan 16, 2010 | Pioneer HTD-540DV System
Progressive scan
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Feb 27, 2008 | Pioneer HTD-330DV System
PT FAN ERR
There is a fan located inside the unit used to cool the output chip. I iwould take a look to see if it is full of dirt, or is not turning.
Oct 03, 2007 | Pioneer HTD-510 System
DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
May 04, 2007 | Pioneer HTD-330DV System
5 disc tray opens and then shuts
Your problem could be one of three differnt things. It could be that the open close switch on the front has a bit of resistance to it, sand when you press it the switch starts to conduct and then the machine thinks someone has pressed the open/close switch again, or there are a set of small switches inside the unit that the door makes contact with when it reaches the end of the travel lenth, that is binding or broken, or there is a problem with the switch or microprocessor circuitry that is affecting the open close command. The correct repair procedture would to be to get a service manual and trace out these devices that I have just described.
Oct 07, 2006 | Pioneer HTD-510 System
753 people viewed this question
 Grubhead
Grubhead
