Keyboard laptop removal for acer 2420
How to remove acer keyboard travelmate 2420 laptop?
  • jgnou Oct 30, 2008
    I have the same problem with my Acer 2200 Travelmate. Is it the same process?
  • 818 Answers
I took it apart b4, and took them apart roughly (the notebook is now not with me) as follows:
1. Wiggle or pop out or take out the cover plate, i.e. the cover with power switch and lights
2. You will see 2 or 3 screws, unscrew them and then wiggle the keyboard out (pull the KB towards the screen direction).
3. Be very careful with the ribbon behind the keyboard .
The most diffiuclt part was to re-assemble the ribbon back to the motherboard. Its very easy and took about 10 minutes to replace the KB. Thats about it.
Sergio
Posted on Mar 13, 2008
Laptop keyboard prepair
Repairing keyboard has not been successful for me. I recommend that you REPLACE the keyboard. NEW keyboards cost less than $20.
Sep 13, 2013 | Acer Travelmate Series 2410, 2420, 2440,...
Tip
Making Functional Bluetooth on Acer TravelMate 2420
<p>Laptops are ideal for business and personal use by its compact size and capabilities. Bluetooth technology in combination with a notebook PC extends its use and effectiveness. The Acer TravelMate 2420 comes equipped with Bluetooth and can be functional in a few steps. <br /> <p><br /> <p>1. Download Bluetooth driver in the Resources section. <br /> <p><br /> <p>2. Follow the instructions to install the driver for your Acer TravelMate 2420. <br /> <p><br /> <p>3. Press the "Bluetooth Communication" button on the front of the computer. The button is located on the left side of the "Wireless Communication" button. The light will remain lit to indicate that Bluetooth is ready to run on your computer. There will also be a Bluetooth icon visible on your screen. <br /> <p><br /> <p>4. Prepare your paired Bluetooth device. Acer TravelMate 2420 is ready to connect to your Bluetooth device. <br />
on Jun 26, 2011 | Acer TravelMate 2300 Notebook
How do i remove the cover on my acer 2420 laptop to replace the cmos battery?Some one please help
You have to probably remove all the screws under the computer. remove the hdd memory and etc. The next part will be to check near the keyboard if there is something to pull out, underneath that there will be more screws to pull out and you will the cmos battery.
if your computer is the aaccer travelmate 2420 you can also check this website http://www.wiquestions.com/questions/les-instructions-de-demontage-pour-un-acer-travelmate-2420/
it's in french but just translated with google
Pascal
May 20, 2012 | Acer Travelmate Series 2410, 2420, 2440,...
Acer travelmate 2420 error "remove
go to BIOS by pressing F10 , DEL or F2 key and go to advance and chose first boot device as hard drive , save and exit.
Jul 10, 2011 | Computers & Internet
I have acer travelmate 2420 and i am unable to write some character in caps using shift+, but i can write them with caps lock on.
hello
i suggest replacing the keyboard-- here are instructions how to remove keyboard
pleade rate me with 4 thumbs up
if you go to this link to make a purchase, http://www.hootoo.com/acer-travelmate-2420-laptop-keyboard-p-51629.html?gclid=CJOHkbernaYCFQO8KgodvQmzoQ
detach the power cord from notebook and remove the battery.
You need to remove the cover where the power button is located, be careful as there is a ribbon cable attatched to the mainboard under here to pulling to vigorously may cause the cable to get pulled out. Then you need to remove the screw(s) holding the keyboard down, once this is done lift the keyboard away from the and lay it face down on the unit so that you can see the mainboard. You need to look where the keyboard connects, to the left of it you are looking for a switch block, if you have one of these then you need to switch the switch labelled "1" to the other position and turn the unit on and enter the bios, this should bypass the password. Once done turn the unit off and and put the switch back to its original position. Then you need to put the unit back together.
If you dont have a block of switches you're looking for two triangle shaped solder contacts on the mainboard in the same area to the left of the keyboard connect, they should be pretty easy to find as they are the only triangular shaped contacts around here, you need to short these out, and turn the unit on while still shorting them and enter the bios, this should clear the bios."
Jan 03, 2011 | Computers & Internet
Reprogramming Acer Travelmate 2420
Hey,
read this page on how to reinstall or upgrade windows xp
http://support.microsoft.com/kb/316941
Thanks and good luck.
Ekse
Apr 26, 2009 | Acer TravelMate 270XV Notebook
Break bios password in acer 2420 travelmate laptop
remove the cover which has your power button and covers the LCD cables. Remove the keyboard and flip it over, being careful to not pull too hard on the cable. There's 2 small triangular silver connection pads beside the keyboard connector on the main board - connect them together and power on your computer (flat screwdriver works fine). Press the f2 key - you'll find it doesn't prompt you for a password. You can lift off the connections now. Go to exit and save changes, and you're password free.
. . <-connect these
. . . __________________
. . . __________________ <-keyboard connector
Apr 05, 2009 | Acer Computers & Internet
Microphone connect have acer aspire travelmate
It appears that your Acer has 3 ports in the front center bottomportion of the laptop. One of them should be for plugging in an external microphone, one should be for external speakers, and one should be an input jack.http://complap.com/yahoo_site_admin/assets/images/acer-travelmate-2420-2.192120139_std.jpg
Feb 27, 2009 | Acer Aspire One PC Notebook
I have my acer travelmate 2420 laptop. Some of its keys like P, 1, etc are not working. Is there any troubleshooting steps for checking the keyboard or I need to replace the keyboard?
Keyboard needs to be replaced. - Go to Acer.com they should have instructions on how to replace the keyboard. Then google this "Keyboard acer travelmate 2420" this should give you some prices for the keyboard. Should be around $24.00
Dec 30, 2008 | Computers & Internet
Acer Travelmate 7510 series keyboard removal
see it this applies to your model
http://www.kriyayoga.com/how_to/how_to_replace_hidden_ram_slot.html
Nov 22, 2007 | Acer NSK8458AN Keyboard
Computers & Internet Logo
822 people viewed this question
David Payne
David Payne
