Its really a very helpful site for the businessmens.it bpo cos is one of the best company.
top bpo companies
This is very exciting topic,it contains lot's of info,anyone who wants to be the part of bpo process absolutely he i'll get lot's of knowledge in it.
seo projects
Yes i appreciate your words,its really very great one this one very helpful blog for the business men.the i'll absolutely get lot's of information regarding seo process that how it works.
seo projects
Hi, by default the Linksys router is set to DHCP... So all you have to do is connect an ethernet cable from your modem to the WAN/Internet port of the router and then connect a PC to one of the ports, see if that will be able to connect to the Internet if not, try to do a power cycle (turned off everything and then turn on the modem first and wait for all the lights to be stable and turn on the router and then the PC) once the computer gets online you may connect the rest... should you require to connect more than 4 PCs, you may need to have a switch but with this setup the physical connection should be
Modem to WAN port of the Router to Switch port and all PC should be connected to the Switch's ports
