Question about SanDisk Sansa e250 MP3 Player
Sansa e250R how do u change the mode?
  • 8,596 Answers
The manual is particularly unhelpful in this department - use the bottom of the turnwheel to scroll down and middle button to select the mode.
Posted on Apr 08, 2008
Sansa e250R
Download the Sansa Recovery Tool from Sandisj's website
Oct 23, 2008 | SanDisk Sansa e250 MP3 Player
SANSA e250r ??
my sandisk 250will not change songs it is stuck o #1 icannot move it up or down
May 03, 2008 | SanDisk Sansa e250 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Switching USB modes to get to micro sd slot...
You have the newest version, indicated by a V2 on the back of the unit. You do not have the MODE option on your device.
The memory card shows up as part of the total memory, you cannot access it separately.
If you mean on the PC, it does not show up in Windows Media Player 10, but it does in WMP 11. If you are using Rhapsody, it does not show. It also shows up in My Computer as a Sansa e250R, right next to the device.
Best of Luck.
Please RATE my solution BELOW.
Nov 21, 2007 | SanDisk Sansa e250 MP3 Player
Device not connected
The Sansa Media Converter will only detect the device in MSC mode, or Plays For Sure (e250R) mode.
Change the mode in the Settings>MODE or USB MODE on the device and re-connect.
Best of Luck,
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
New player, says I ran out of space
If you formatted it thru Windows Media Player, or Rhapsody, it didnt really format properly. Make sure the device is in Rhapsody Mode. Settings>Mode or USB Mode>Rhapsody. On your computer go to Disk Management. Right Click on My Computer and select Manage. On the next window select Disk Management, under Storage. On the right side at the top of the window you will see the device listed (i.e. Sansa e250r). Right click on the device and select format. Dont select any other options, just hit Start. Your device is now formatted properly. Best of Luck.
Sep 13, 2007 | SanDisk Sansa e250 MP3 Player
Used memory i never used
With most MP3 players, some of the memory is used for system files and software. Just delete all the things you done use (i.e. pictures, playlists, Rhapsody Channels) and whatever space you have free is what you have to work with.
If you want more memory, I highly suggest a microSD card
Aug 12, 2007 | SanDisk Sansa e250 MP3 Player
Help
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Apr 27, 2007 | SanDisk Sansa e260 MP3 Player
Finding the music to delete
Use Media Monkey instead, or change Windows Media Player's configuration, so that it sees more songs.
Jan 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
