Marantz sr 73 amp/ receiver
It goes in mute after few seconds. what cud b the reason/ pls pls
  • rajbohra Mar 14, 2008
    hi! in bigning only one channel was getting mute and after few minutes both channels go mute. now when i start after few hours it works for five or the minute normal then it goes mute... pls help me
  • Albert Nika May 11, 2010
    Hi: Is this stereo? Do both channels go mute at once?
Enciende el displey no responde las operaciones del panel de control. panel enciende con 0000000000.
Posted on May 05, 2011
  • 1,512 Answers
Hi raj
what happens when you turn up the volume... does it come back in again... if so it could be a faulty speaker protection relay, or at least dirty contacts to same. Can be fixed by burnishing the contacts.
Let me know if sharp increase of vol changes the muting problem
regards
Graeme
Posted on Mar 16, 2008
I have a Marantz sr 870 that was working fine when last used. It has been sitting a few years. I now have no output to the speakers or to the headphones. Mute is not on. Please help?
There is a repair manual http://www.manualsparadise.com/service-repair-manuals/Marantz/SR870/RWSPFM-63663893-1
I cannot speak to the company that sells its reputation. The issue is most likely due to the protection circuit in the final audio section. Most use a relay to disconnect the speakers in the event of an overcurrent condition. The relay can fail for a number of reasons.
Dec 02, 2016 | Marantz Audio Players & Recorders
Kodak Easy Share zoom digital camera
Most problems of this symptoms indicates either:
1. Weak battery; or
2. Internal fault (which can either be hardware or software).
Initially, pls try removing the batteries for an hour or so hopefully doing a reset and will work from thereon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 03, 2008 | Cameras
Need Help
I think you've answered your own question, circuit power is not going from one side of the DSP chip to the other and that suggests that the DSP's core is at-least partly DOA. You are indeed correct that functional power should be at 3.3V and yes 0.3V does make a difference to the components that rely on a 3.3V feed, however if the DSP is fried you are not going to see normal functionality or be able to diagnose further.
Sep 04, 2007 | Audio Players & Recorders
How do I fix the sound on my Emerson Flat Screen Telivision.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 05, 2015 | Emerson Televison & Video
My sansui ctv-svb2108 is out of service because of problem with the memory ic-M2001.where cud i get an original one.pls hlp me
There will be a number printed on it. This number is important to note. Buy the same number. That is all.
Dec 02, 2012 | Televison & Video
My marantz sr 5200 has stuck in "Mute on" situation
Your mute switch has been broken some how,End will have to be replaced.
Oct 11, 2012 | Marantz SR-5200 Receiver
No output regardless of input- cd, fm, am aux.
Is it new to you?
Make sure there are jumpers connecting the rear like in the picture.
http://www.soriaudio.com/zboard/view.php?id=m_2nd&page=3&sn1=&divpage=11&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=193214
UN-select anything to do with Tape or Muting.
Feb 13, 2011 | Marantz SR-92 Mark II Receiver
Just picked up a Marantz SR-19, Everything looks like it works but I get No sound out of it. Unfortunately, there is NO remote and was wondering if there is a setting like Mute or a speaker select on the...
A Mute indicator would tell you if it was muted. Make sure no Tape or Multichannel Input are selected by mistake.
There are supposed to be jumpers across the Pre_Outs to Main In's in the back when you're NOT using external amps. You could substitute short RCA cables.
Jan 28, 2011 | Marantz SR-19 Receiver
I have a marantz sr 7001 amp and am running canton 4ohm speakers to front and centre should my amp get really hot and go into protect mode when I am giving it some serious volume
it is not made to drive 4 ohm loads.also if you measure the impedance on the speaker,at some frequencies,it is closer to 3 ohms.This will cause the amplifier to shut down.Today's amplifiers are embellished specs.the old marantz 2325 was 125 watts a channel and weighed 80 pounds.It would eat alive some of the 1000 watt home theater amps of today.Marantz is very nice stuff.
Jan 03, 2011 | Marantz SR-6300 Receiver
1,017 people viewed this question
 Grubhead
Grubhead
