Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
I tried using a 800mm
By derf69 on Mar 13, 2008
i tried using a 800mm lens with a 2x teleconverter on my canon digital rebel every time i press the shutter button i get err code 01 what does this mean
Solution #1
posted on Mar 13, 2008
Not Rated)
devocap
Rank: Guru
Rating: 86%, 165 votes
Hey there derf69, the error code "err 01" indicates the need to clean the lens contacts, which in your case you have several. I suggest you completely clean the contacts using a contact cleaning solution which dissappears completely. you can also use a clean eraser to effectively remove any resilient buildups. I suggest you completely disassemble your lens configuration, and rebuild, once all contacts on the lens and camera body have been cleaned. There is also a possibility that you may have an incompatibility problem. If the cleaning does not help, please let me know and provide the exact model name and number of your camera, lens, and converter. Good Luck
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
I have a brand new Sharper Image® Mini Portable Camcorder after 1st charge it won't... (More)
Answer
it's just a surveillance camera. How can I install it on my PC?
Answer
i took about 50pictures and checked they were stored in the memorry card ,then after about 30... (More)
Answer
Problem with the E3 auto focus the F-Stop display goes off then I cannot use the camera. I wiped the... (More)
Answer
i lost the plastic piece on the red eye reduction. now my flash is only working at a very slow... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital... Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
