Question about Kitchen Ranges
Hi, I have a Roper bakemaster gas/gas stove heater. I need replacement knob for heater, i believe it is a o'keef & merrit it says "robert shaw" on face. I would like to repplace either just heater knob (off lo/med/hi) or oven knob too if cheap enough, I am using a wilcolator knob for that & it works, but would love my beautiful old stove to look authentic, not missmash. can you help me. I have seen these for $65 reproductions, Yikes. is there some universal knob, or actual used knob i can use. and where do i get one. Thankx so much. lynn
    Guru:
  • 1,894 Answers
Hello
repair clinic mentioned by jaime has onlyu three types of knobs
Posted on Mar 13, 2008
  • dewan nafees ahmed Mar 13, 2008
    mean while for universal knobs you can see these sites too.
    link 1
    link 2
    thank you sir
    good luck
  • 2,326 Answers
Check this site and enter your model number to search for the part you need.
    Master:
  • 788 Answers
Have you tried eBay?
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Knob replacement AEZ72909002 for LG Stove
I'm way too late with an answer here, but I'll add it anyway in case someone finds this page later on. The AEZ72909002 part is not for the LRG30355/LRG30357 series of LG gas ranges, but for the LRG 3095/3097 series. The only explanation I can imagine for LG reversing the knob insertion profile, is to force their LRG30355/30357 customers into expensive repeated replacements.
Jan 17, 2012 | LG LRG30355 Gas Range
We have an old O'Keefe and Merritt stove in a
on most stoves where gas line connects around back should be a gas shut off valve if none put one on
Jun 06, 2017 | Kitchen Ranges
Ariston gas stove has 2 burners not working
the burner themocouples need replacing...
Dec 21, 2009 | Ariston Technologies Ovens
1952 Moffat Bake Stove
I have a working 1952 moffat stove with warming oven if interested
Oct 27, 2009 | Kitchen Ranges
Error on display F1 & E1 Stove will not start
HI. This is a safety flip flop error code, caused by damaged circuitry within the electronic control board. This will require you to have the control replaced asap. This will correct the issue.
Part number (for white control) #3196971
Part Number (for black control) #3196970
Oct 19, 2009 | Ovens
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Kitchen Ranges Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
