Question about Compaq Presario 700 470024-192 Notebook
Screen goes blank
Will boot up and work just fine, then the screen will just go blank...
power and HD lights are still on.. have tried connecting it to a working
external monitor and nothing displays at all.. will sometimes work again
after sitting for hours or days. will run ok then do the same thing again.
any ideas
  • 3 Answers
Try reinstalling xp.(im asumming thats what ur running).
Posted on Mar 16, 2008
SOURCE:
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Blank screen on boot up no hd activity
try removing the lithium "Bios Battery" and leaving it out overnight then the next morning put the lithium battery back in.
Jan 04, 2010 | Everex StepNote NC1500 Notebook
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
Feb 17, 2009 | Dell Dimension E310 PC Desktop
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Hp vectra vli8 p3 continues rebooting
Google bad caps on motherboard. I just revived a VLi8 which had this problem. For the KZM-6120 motherboard that I have there a six 1500 uF, 6.3 volt capacitors lined up in front of the pentium III heatsink. Look for gunk oozing out the base of the capacitors. This is a well-known problem apparently. See here:
http://en.wikipedia.org/wiki/Capacitor_plague
Symptoms sound similar. What mine did was that the computer wouldn't reboot after windows 2000 reinstall, lock up during boot, and the yellow lock light would be on sometimes. I could only run from a floppy. Updated bios, changed HD, nothing worked.
Replaced the six caps, and I have reinstalled system (2000 pro) and everything is working fine.
Feb 01, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Compaq Presario 700 470024-192 Notebook Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
