Question about Lexmark E320 Laser Printer
Lexmark E320 - new cartridge poor print quality
Good Day! My brand new cartridge, will only print in very faint grey. Cannot get it to print black. 3yrs. ago I had purchased a new cartridge and had the same problem. In print properties I have it set at the max. 10 (used to be 8) and all that has done is burn out my cartridge faster (should yield 10,000 copies), and I still cannot read the print clearly. Does the printer need a tune-up? or download? The first two cartridges I had worked great!
Please advise
Regards
  • halcyon1200 Mar 28, 2008
    new Lexmark Cartridge, only print a faint narrow column. Download new OX X .4 driver, still not working right. Running leopard system on my powerbook.
  • 25 Answers
Have you cleaned the print head surface lately? It is located directly above the top of the toner cartridge which you need to remove to do this right. Now using a dry soft cloth reach inside and find the narrow slot and carefully go back and forth with the cloth (sharp metal edges be careful). If this does not solve the problem next try removing the toner cartridge and clean the metal contacts inside the printer on your bottom left side when looking into the open printer also it would pay to remove the transfer roller on the bottom inside this has two black tabs that release the roller the one on your left (again looking into open printer) should have a metal strip that should be free of toner on both sides this will also cause poor print.
Luck
Posted on Mar 29, 2008
My printer will only print in red. Even with a brand new black cartridge. What can I do?
Color cartridge faulty, if you want color printouts replace new color cartridge.. Select "print in grey scale" in printing preferences,if you want to print only in back & white.
Aug 12, 2012 | HP PhotoSmart 7760 InkJet Printer
Faint grey printing
According to the service manual for problems with light print image, the cause can be the Developers or High Voltage Power Supply (HVPS). Other possible causes are given as: Developer roller is stained when the toner or developer cartridge is almost consumed. Ambient temperature is below 10 degrees Centigrade. Bad contacts with the HVPS or abnormal output from the HVPS. To replace the Developers you would need to purchase a replacement Imaging Kit CLP-R300A. Any problems in the HVPS would require a factory repair.
Dec 13, 2011 | Samsung CLP 300 Laser Printer
Black printing very faint or not at all, cleaning print head makes little difference Brand new Cartridge
Sometimes it will print faint black even if there is a new black cartridge, because the color cartridge needs to be replaced as well.
Make sure that the cartridges are genuine Kodak cartridges, as well, for maximum performance and reliability.
Cleaning heads can use up a lot of ink, by the way.
Jan 13, 2011 | Kodak ESP 5 Printer
Quality starts out good, and then fades quickly
You probably running out of black ink. Try replacing with new black ink cartridge.
Try to run a test print.
Jul 18, 2009 | Office Equipment & Supplies
Printing illegible, very faint
I run "clean printhead" and that solves the problem when it happens to me.
Mar 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Dell 720 prints faint
Have you gone into printer properties when printing the item then click advanced check what the settings are on. Your default settings may be to print draft quality which produces faint picture because it uses dramatically less ink. If you need further assistance let me know. Also a brand new printer of higher quality can be purchased for around 30$. So repair is definitely not a viable option if it is not a setting problem.
Thank you,
lee
Mar 01, 2009 | Dell Inkjet 720 Printer
Printing problem with Canon iP2600
Appears to be a defective color cartridge. Verify the printing is not set to fast or draft.
Dec 15, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Black cartridge problem
Hi , good day , try to do head cleaning until the black print will appear perfect in color.
May 05, 2008 | Epson Stylus Color 460 InkJet Printer
All colours are faint. The black comes out grey.
hi clean your cartridges clean your cartridge head nozal with the printer software goto to start-> settings->printers and faxes-> select your printer->right click->properties->tools-> find options like clean cart or nozals.
check printer settings for best ,normal,or draft set as best and try. may helpful.
Mar 03, 2008 | Canon Pixma MP800 All-In-One InkJet...
Lexmark E320 Laser Printer Logo
220 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
