Question about Palm Treo 650 Handheld
W668 when i put in my sim card phone turns off and on what should i do?
    Problem Solver:
  • 4 Answers
This is caused by bad contact between the phone and sim card.
I had the same problem, and I simply put 3 small squares of paper on the bottom side of the sim card tray.  This ensures the sim card keep in contact with the phone at all times.
Posted on May 10, 2008
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Insert sim card
I'm not sure what the question is you are asking concerning a "sim card" but if it's How to put a SIM card in your cell phone you need a pin to put in the hole and it will pop open, However if your question is that your phone keeps telling you to insert a SIM card then you need to turn off your phone first and then go into the place where it's at and remove the SIM card and then put it back in and then turn your phone back on.
Aug 03, 2013 | Samsung E1107 Cell Phone
How do i enter the nuc code on a samsung wave mobile phone
Samsung SGH-a300
*2767*637#
Samsung SGH-a400
*2767*637#
Samsung SGH-a800
*2767*637#
Samsung SGH-e400
*2767*688#
In newer phones:
#*7337#
Samsung SGH-e500
*2767*688#
In newer phones:
#*7337#
Samsung SGH-e700
*2767*688#
In newer phones:
#*7337#
Samsung SGH-E715
Turn off the phone. Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another SIM Card. Turn on. The code is 00000000.
In newer phones:
#*7337#
Samsung SGH-m100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
Samsung SGH-P400
*2767*3855# or *2767*688# or *2767*927#
In newer Samsung models:
#*7337#
Samsung SGH-s100
*2767*7822573738#
Samsung SGH-s105
Remove SIM Card. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Samsung SGH-s300
*2767*7822573738#
Samsung SGH-s307
In newer phones:
#*7337#
Samsung SGH-S500
In newer phones[/color]:
#*7337#
Samsung SGH-600
*2767*3855# or *2767*2878#
Samsung SGH-2100
Samsung SGH-V200
*2767*7822573738#
Samsung SGH-X100
In newer phones:
#*7337#
Samsung SGH-X600
In newer phones:
#*7337#
Samsung SGH-R210
*2767*3855#
*2767*2878#
Samsung SGH-D500
#*7337#
Samsung Universal Type
TEMPORARY UNLOCK:
Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
May 30, 2010 | Samsung Lands Phones
Where to put the sim card
Open the back cover of the phone, remove the battery,slip the sim card into the slot designed for the sim card. Later, install the battery,put back cover. Turn power on. That's it.
Dec 31, 2009 | LG HD4000
The v3 keep askin for my sim card but the card is in what can i do
Turn off the phone
Remove the SIM card
Wipe the metallic portion on the back of the SIM with a cloth
Put the SIM card back in
Turn the phone back ON.
If this did not resolve the problem, try using another SIM card so that you could verify if the problem is the SIM card or the SIM slot.
Have a great day!
Sep 18, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Sim Card Problem In LG Vu
This happened to me too. A temporary fix is turn off your phone and put it in front of a really cold air conditioner for about ten minutes. Then turn it on but make sure you keep it in front of the ac to keep it working. What happened is your sim card reader has a thermal problem so you will need to take it in unless you want to spend all your time in front of the ac (which will get expensive...)
Jul 01, 2009 | LG Vu Cellular Phone
Cant get my sciphone to work
okay turn your phone off take the back off ,battery and take the sim card out now put the battery back in with out sim card .. turn on. now go open sim and close sim 2... turn off...remove back and battery put sim card in slot 1 make sure its in all the way put battery and back on ... turn the phone on... give it a few minutes it should work....
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
HELP....phone reads "enter sim card" when sim card is in the phone
YOU HAVE TO CLEAN THE GOOLD COATED TERMINALS WITH A SPIRIT WERE THE SIM ENTERS AND ALSO CLEAN THE SIM WITH DISTILLED WATER OR SPIRIT DUB DONT RUB.DONE BY DOGY
Aug 02, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
