I am trying to find out a way to finalize a DVD recording on my recorder. I purchased it 2 months ago and when you go into the menu to finalize the recording it dims and acts like it does but the DVD will not play on anyother player. I also would like to know about getting another remote for my recorder due to my son dropping mine in water. Thank you Katherine rivers e-mail [email protected]
    Guru:
  • 1,894 Answers
Did you try different disks?
this will help you solve the problem of finiaising
Posted on Mar 13, 2008
  • dewan nafees ahmed Mar 13, 2008
    please mention the model number and the make in detail
SOURCE:
LG DVD recorder RH735T. Page 10 of the manual says to finalize a disc before you can play it on a different unit. But when I record something on a disc, the settings menu will not allow me to finalize
On my Toshiba DVD burners, you need to first open the DVD tray, and while it is open hit the regular menu, then DVD menu, select "FORMAT" from the DVD drop down menu, then "FORMAT MODE", which leads you to the 2 CRITICAL Choices :
1) Video Mode - Which has the DVD recording in "DVD Compatibility Mode" so it is "Compatible" with most other DVD Players
OR...
2) VR Mode- Which says "Editing Possibility mode" (Note you need a "+R DVD "to be able to do editing, at least on my machines.
Obviously you'll close the DVD tray to be ready to record
Finish the DVD, @ "DVD" Menu, & Finalize, or what you need with "VR"
Mar 02, 2014 | LG Televison & Video
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
Sony RDR-GX350 not able to read recorded DvDs anywhere else except in this unit
Here is the manual. Page 99 shows you how to rest the recorder to factory defaults. https://www.sony.co.uk/electronics/support/res/manuals/3113/31137591M.pdf
Oct 29, 2017 | Televison & Video
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
The DVD recorder quit finalizing the disks
try cleaning the lens, if your cd's are ok.
May 27, 2009 | RCA DRC8300N DVD Recorder/VCR
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but...
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Mar 04, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Playing recorded DVDs on PC or other DVD player
Hi
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Thanks
T.Boopathy
Aug 23, 2008 | Philips DVDR3455H/37B
Samsung DVD Recorder R155
Sounds like you recorded from a camcorder attached to AV2 (front of DVD player). Press the STOP button, then open the menu and finalize the disk.
Mar 04, 2008 | Samsung Televison & Video
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
