Pioneer QX-949 We have a Pioneer qx-949. It will power up. We hear the relay click like it's going to work for a second. Then it makes a little tick sound and it won't produce sound. We love this unit! Please help us find a solution.
From Charles (owning a QX 949, still working but with some investment into repairs by myself) :
QX 949 contains a "power protection cirquit". This cirquit reacts aswell on short-cirquit (either within the output-amplifier cirquit {transistors} or by faulty speakers) as on overload (by playing musik toooo loud).
Your QX 949 might therefore either be affected by short-cirquit within one of the four output amplifiers or there might be a problem within the pre-amplifier or power section, causing an AC or DC signal to appear at the inputs of the output-amplifier section and therefore overloading the output, as if music was played too loud. First basic test: does the discribed "tick sound" (which means that after power-up the protection cirquit releases the relais again) also appear when the volume is turned down completely ? If not, the fault must be a signal produced within the pre-amplifier section before the volume regulation. If yes there still could be a pre-amp problem after the volume regulation but it´s more likely to be found within the output-amp section. One won´t get round to measure this section (oscilloscope) at it's signal inputs to exclude a faulty signal to arrive there. If this is not the case I would recommend to disconnect and reconnect the four output-amps from the power supply one after the other, for finding which one causes a short-cirquit. But before doing this: try out what happens if you change QX 949 into 2-channel mode by turning the socket on the rear panel. Doing this the output amps for the rear channels are deactivated. If your QX 949 was working under these conditions it would limit your further search to the amps for the rear channels.
There is also a small chance that the power-protection cirquit as such is faulty or that the power supply contains problems. The power supply has got 6 fuses that you will find underneath the bottom plate. Are they all still ok ? (If one of them is broken then there can be a positive or negative supply to the output-amps as these are receiving + and - DC-currents from the power supply)
Basically: this amplifier is almost about 30 years old. As the lifetime of electrolytic capacitors ends after about 15-25 years there appears the need to replace them all (on all the prints). I did it with my QX 949... but you definitely must love yours to do that, it's quite an investment of patience and time.
And: servicemanuals.net display on their webpage availability of QX 949´s service manual. If you can't find it I might be able to scan some pages.
Charles (Switzerland)
Posted on Mar 28, 2008
Hello
I have one to, with i think the same problem.
Change the trimmers on the output board, then it works again, my did.
best regards
Torben Schellerup (Denmark)
Posted on May 13, 2009
I bought this new in the early 70's and love it, but, I now find trouble with the push buttons..They are not working well and I have to push several different buttons and my speakers will pop on and then turn off. Is this a problem with the buttons and can they be cleaned. Also I don't know if the push buttons can be removed for cleaning...Any help would be really appreciated. Thanks Paul
Posted on Mar 11, 2010
I have a pioneer 949, great amp but I lost the sound. It fires up but won't play sound . Don't want to lose this amp. please help
Posted on Oct 06, 2008
My nissan maxima qx 2.0l v6 wont start what can be the problem
Write your answer...i need help! For valve timing the car had engeen down an am fixing it and i dnt knw how to put the timing corrotly name of the car is nissan v6 Qx 2.0l maxima double top
Apr 18, 2015 | Nissan Cars & Trucks
I have a phoenix gold Qx 180.2 amp and im gonna push two 10" comp kicker subwoofers. will it work
Do you no the continus whate rateing of it? End i don,t mean peak or maximiun Watts on it, All so the RMS) watts that the sub will handle,
Nov 12, 2012 | Phoenix Gold QX 180.2 Car Audio Amplifier
Universal remote control codes for akai qx-5690UFX
Check with the universal remote control from philips
Jan 07, 2010 | Akai QX-5690 UF Shelf System
I have a Pioneer DQ-4000 receiver. Honestly I am
I think what you are looking at is referred to as a banana plug connector. You do not need to buy these connectors to make this work. If you unscrew the plastic connector out far enough, a hole from the side opens up so you can put your copper conductor through and tighten the plastic peice down. The banana plug is probably better for easy connection but using this method is just as good.
Oct 28, 2009 | Pioneer Audio Players & Recorders
Hi I have a pioneer receiver QX-8000A4Cannel that needs a new four ganged potentiometer 500k ohm volume control. Where can I purchase a new one.Grateful for any info and assistance. Regards Reg
Hi rp
You can get parts in the US direct from Pioneer. I have done a search for you and there is a parts list that mentions several vol controls. Click here
They have no stock however, and supply may be ex Japan. If you are not in the US, let me know where you are, and I will line up the correct website for you.
regards
Graeme
Apr 16, 2008 | Audio Players & Recorders
Kenmore h3 Elite Hot/Cold Water problems
I wouldn't imagine it being a computer problem, computers don't make mistakes like that. I would start with the inlet valve http://www.partselect.com/xq/aspx/Inventory.391478/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 and maybe the inlet valve wiring harness http://www.partselect.com/xq/aspx/Inventory.391563/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 for good measure. Both parts together will run you less than $100 and shouldn't be that difficult to replace. I'm am no Washing Machine expert, I just go by my common sense and Google. The computer http://www.partselect.com/xq/aspx/Inventory.971890/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 is $250+ and like I said I don't think the computer would cause the valve to open slowly and stay open, sounds like the vavle is sticking. Good Luck!
Apr 14, 2008 | Kenmore Elite 45986 Front Load Washer
1,627 people viewed this question
 Grubhead
Grubhead
