Device driver sir i have audio problem .when i reinstall window my audio sound mute while visual seen in windows media player .what i do when i try to setup the audio driver the message shown that" there is no audio device found"
  • zvonimir Mar 23, 2008
    problem with audio and modem driver
  • DIGITALDANNY Mar 25, 2008
    NO SOUND AFTER LOADING WINDOWS MEDIA PLAYER 11,WINDOWS RECOMENDED UPGRADE.ERROR MESSAGE ,CANNOT PLAY CD OR DVD,NO DRIVER OR INSTALL NEW DRIVER OR OLD DRIVER NEEDS TO BE UPDATED.12 DRIVERS ARE SET UP 1THRU 12 IN DEFALT MODE.PURCHACED DRIVERS ON LINE BUT NO SOUND AFTER DOWNLOADING OVER 4000 CDS&DVDS&KAREOKE THEN BACKING UP ON THREE EXTERNAL HARD DRIVES.
    Sergeant:
  • 201 Answers
Hey there byadava, when you reinstall an operating system, the memory gets totally wiped when it is reformatted. The result is that all the system drivers for your motherboard are also erased. You will need to get the drivers for sound, and other things as well. They can be found at the manufacturer's support site. They are free and you simply choose from a list of possible downloads they provide. If you need help with that step let me know, and please provide your model name and number. Good Luck!
Posted on Mar 13, 2008
SOURCE:
No Audio Device
Try using the VLC Player. It comes with drivers and codec. I've seen it solve problems with sound and audio.
Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
If VLC Player works try your media player again. It might be necessary to reinstall Windows Media Player if it still gives you the error message.
May 30, 2012 | QDI Group QDI SynactiX 5EP-A (SYNACTIZ...
There's no audio in my computer
If you are using speakers on a desktop computer, the first thing to try is to test your speakers on a different computer. If they still don't work, then it's time to replace them. If they do, then there a few things to do.
You would first have to test the speakers on a different audio port & see if that makes a difference. If it still doesn't work, the next few steps will also apply if you are using a notebook.
Check to make sure that the volume is all the way up and NOT set to mute.
After making any adjustments to the volume, try playing any media file & see if the media player volume is also correctly set (cranked up, NOT muted).
(*) In the event that it comes up with an error, read it: it might say something about not having a sound device installed. If it does, then you will have to either download the audio drivers from the Manufacturer's website OR re-install it from the drivers CD that came with your computer/motherboard; if not, see below.
If you have Windows Vista or Seven with either HD audio or HDMI-capable display adapter, right-click on the volume icon near the system clock and choose Playback Devices.
Something like this should come up:
Make sure to select the CORRECT DEVICE. If your computer is connected to an HDTV, choose HDMI. If it's a notebook computer, choose Digital Output. Otherwise, select SPEAKERS as seen above.
If all else fails, you will have to uninstall then re-install the sound drivers.
In Windows 7 or Vista, click on start & type "Device Manager" in the Start Search box and click on the Device Manager icon that appears in the results list
For Windows XP, Click on Start -> Control Panel -> System.
The System Properties window pops up; click on the "Hardware" tab then click on "Device Manager"
In the Device Manager window, open the Sound, video and game controllers.
Right-click on your audio device and choose "Uninstall"
When prompted, restart your computer. It should work after that. If it does not, it will provide an error message that will determine the actual cause of the problem. You may end up downloading the drivers as detailed in the (*) section above.
If the drivers will NOT install and says there is no compatible hardware, then the audio device has stopped working & will need to be replaced. Any other error would pertain to the operating system and would be a completely different issue.
Aug 25, 2011 | Computers & Internet
I have this message apprear on my laptop when i try and play sound "Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device...
try playing the sound file with other media players, if still not playing reinstall ur audio driver either by dowloading the driver from internet or by installing it from ur driver cd.
if ur audio device driver is integrated or plug n play device then,
step 1:open control panel
step 2:open 'sound speech and audio devices'
step 3: in the property menu of audio devices select drivers from the tab
step 4:select uninstall driver.
step 5: restart ur computer and the audio device will be reinstalled.
if it is the problem with ur windows media player, then step 1:select option/preferences from the menu.
step 2:select devices from the tab.
step 3:test all the devices by selecting each one at a time to play ur sound file.
Jun 19, 2011 | Acer Computers & Internet
No sound
Hi, Confirm again is Volume controller not mute, Ifit confirmed, not in mute,
check the all players Check and confirm all video and audio players in your laptopare not mute or very less Volume state. Video or Audio Players like : WinAmp, Windows Media Player,VLC and so on... If everything fine, check the Sound Card drivers areinstalled and working fine. If not youneed to installed the appropriate drivers, To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codecs, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If yes, need toinstall the drivers. Download the drivers from Website or if you have Motherboard CD, > insert the motherboad CD, browse>select audio driverfrom CD or downloaded path >install. After completion, restart computer andcheck.
Jan 19, 2011 | Gateway Computers & Internet
The volume of my computer is not muted at all but when i play a video or any other audio song the sound does not come out so what should i do.
Hi, Confirm again is Volume controller not mute, Ifconfirmed not in mute,
• Go to Start>
• Control panel>
Jan 19, 2011 | Computers & Internet
My computer doesn't have a sound anymore..Everytime I go to media player to play some music it won't play...
Does this just happen when your trying to play music or a movie?
When you boot the system do you get the windows log in in sound?
If you do try reinstalling windows media at this link.
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Nov 04, 2010 | Microsoft Computers & Internet
WINDOW MEDIA PLAYAR NO SOUND
***Codec issue If only some of the movies you're playing do not get sound it's likely you have a codec issue. codec downloads.
***Check volume settings Often no sound in the Microsoft Windows Media Player is corrected by adjusting the volume controls at the bottom of the window. Moving the slider from the left to the right will turn up the volume, if all the way to the left the volume is turned all the way down.
***Make sure not muted In addition to the volume slider, make sure the sound icon is not pressed in. This button is the mute button and will mute the sound.
***Sound Driver Drivers for your sound card download this http://www.devicedoctor.com/device-doctor-download.php
***Update / Reinstall the Windows Media Player
If you continue to experience issues, you may want to consider reinstalling and/or updating the Windows Media player on your computer. You can find the latest Windows Media player on your computer by clicking "here".
Oct 06, 2010 | Computers & Internet
There is a problem with your sound device so the windows media player cannot play the audio
pl reinstall the drivers from the mother board cd or download it from the manfacture website
Sep 02, 2010 | Microsoft Windows XP Professional for PC
Sound is muted
Could you please check the following for me.
1) Open windows media player and attempt to play a song, does windows media player bring up an error message or does it just play without sound?
2) Go to your control panel and click on sound, make sure nothing is muted.
3) In sounds again, look for a list of usable devices, if there is more than one, try each and until you get some kind of sound.
If Windows media player gave you an error message try updating your drivers with the links provided.
Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-50979-1&lc=en&dlc=en&cc=us&product=3224052&os=2093&lang=en
Windows XP
For XP you may need to download two things, the drivers on this page and Microsoft Universal Audio Architecture.
Drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-45570-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=3224052
Architecture
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-47284-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=3224052
Jun 22, 2009 | HP Pavilion dv6000z Notebook
Sound troubleshoot
first thing you can do is uninstall 11 and then reinstall it. but before you install media player 11 again uninstall the previous version 11 doesn't upgrade ..what sound device do you have???
Aug 18, 2008 | Creative Labs Sound Blaster Live! 5.1...
Open Questions:
bxshhj AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 20, 2019 | Amazon Computers & Internet
^%#@*& Amazon Prime rEfUnD pHoNe O*^%{+1++85O++8I2++4OO9*^ how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Computers & Internet Logo
96 people viewed this question
Ekse
Alun Cox
