Finding a Part for Memorex MVD4540
I have a Memorex MVD4540. There is a small plastic wheel inside that has a broken tooth that prevents proper operation of DVD player. All I am trying to do is find out where I can order or pick up this part. I'm in Ontario Canada near Michigan border. I'm not sure where the manual is so don't know where to phone. Web search is producing all kinds of sites except what I'm looking for.
  • 2,326 Answers
Here is the service manual for your DVD.
Dowload it and the list of all the parts is there.
Memorex Contact Information Main support number1-877-Is-It-Live OR 1-877-474-8548
Posted on Mar 13, 2008
I have a SPL-TXC122a shredder and I need the plastic drive gear Know where to get one?
I tried to get one for my machine but to no avail. So I fixed my gear myself. Go to your local hardware and buy a "Devcon" plastic welder. Not inexpensive.
You have a broken tooth on the plastic gear. Use a very small
drill bit the size of a big paper clip. drill three holes where the tooth broke off ( if part of the gear tooth is still there, file it down smooth.) Cut three pieces off a paper clip and insert them into the holes. Make them extend to below the gear and not to extend above the original tooth. Now you will make a tooth with the plastic
weld. Fill where the broken tooth was and let it set. Also fill where the paper clip extends below the tooth. This will give it more strength. Let it dry and harden. Now with a small file, file it to make it fit to the next tooth so it doesn't make a bump. " if you can before the mix dries, replace the gear and turn by hand the steel gears to make a smooth fit. Wipe any excess mix away. Good luck....
PS. mine is still working after three years....Hint do not try to shred
to many papers at one time. And once in a while put some 3 in one oil on a piece of paper in a sig sag motion and run it thru the machine. This will help to quiet the noise and oil the cutting blade.
Nov 04, 2014 | Office Equipment & Supplies
There is a loose part rattling within my transparency hood which prevents it from working - how can I repair this ?
I just had this problem too. What has probably happened is that the belt/wheel assembly within the upper lid has broken loose from its plastic housing. It is normally retained in place by two weak plastic posts, each having a plastic extrusion that holds the metal housing for the wheel in place. Just minor stress can apparently snap off the plastic extrusions. (Nice quality workmanship, Epson.)
Unplug the upper lid and remove it. Unscrew the 5 retaining screws and then use a small flathead screwdriver to carefully pry the bottom of the unit away from the rest of the housing. Stabilize the wheel mechanism so that you can rotate the whole unit around in order to grab the broken plastic pieces and small spring without allowing the wheel mechanism to crash into things. Superglue the two broken plastic pieces to their proper mated location on the lid, and wait about half a day for a solid bond. Then fit the wheel housing over the two plastic pieces so that the thin silver bar is pointed toward the back of the lid. (Do NOT place the spring over the thin silver bar yet.) Fit the orange belt properly around the wheel. NOW, push the wheel housing carefully toward the front of the lid until there is slight tension in the belt. Squeeze one end of the spring over the thin silver bar and push the spring completely into its recessed plastic trough while compressing it. Reassemble, and you're done.
Sep 01, 2010 | Epson Perfection 4990 Flatbed Scanner
Hookin up vcr
just look and connect the RCA chord,yellow wire connect to vcr video out then to the video in in your tv. then the connect rca chord audio out to vcr then to tv audio in, then set the tv to AV
Jun 19, 2010 | Memorex MVD4540 DVD Player/VCR
Vcr
do you have a cable box/satelite/directtv? yes..okay box out to vcr in....vcr out to tv...(vcr must be set to ch 3 at all time)....no box at all, antenna should be connected to vcr/tv
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
1991 corolla door rod handle plastic clip broken
You can get inside door handle either new or used from sellers on ebay. It should be just a few dollars plus shipping. Just search ebay for "Inside door handle 1991 Toyota Corolla."
Frank
Frank's Friendly Cars Maui Car Rental
www.MauiCarRental.biz
Aug 01, 2009 | 1996 Toyota Corolla
Stuck in Standby
FOr the MVDP1102 Memorex 10.2 portable DVD Player:
I had the same problem. If you open the disc door there is suppose to be a plastic arm underneath the right side of the lid which when you close the lid, with the movie disc in, this arm will press through to a switch inside the machine and that will set the player in load/play mode. Memorex did not have parts for this player, so I unscrewed the bottom and one black screw inside where the lazer light is. This will allow you to handle the bottom back side and see underneath where the screen is you will find the switch. I rigged up a pin wire and did some small drilling. I was successful, but it wasn't easy. Most times I just fail and toss. I thing my son just open the disc door too much and that's how the piece was broken.
Apr 05, 2008 | Memorex MVD2042 DVD Player
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Vrdvd4000 remote
Is there a code for the dvd/vcr memorex player, a universal code?  Thank you.
Dec 19, 2007 | Memorex MVD4540 DVD Player/VCR
Printer not take paper
Look for a small piece of paper or other foreign object stuck in the paper path, or a rubber roller which has gotten slick and will no longer pick a sheet.
A broken gear in the drive mechanism, broken gear tooth, a small piece of broken plastic (from inside the printer itself), all of these can produce a problem like this.
Nov 28, 2007 | Samsung ML 1651N Laser Printer
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
