Question about GE 30 in. Profile JP938 Electric Cooktop
F122 and F123 code
We have a similar problem to those with an F153 code. Intially, we had an F123 code on one of the burners. We killed power to the cooktop, tried a reset, then had an F122 code. We can't use this burner and it has a continual F122 code, even when a hot pan is only placed anywhere near this element. Unplugging the appliance (circuit breaker) clears the code until you place anything hot near the burner or try to turn that burner one; then the F122 code and beeping reappear. We have a frequent "beeping" alert from the cooktop. Any ideas what has failed? I have no desire to pay hundreds and hundreds of dollars to have a technician replace parts that may or may not be the problem. Moreover, GE will not even lift a finger to at least tell us what has failed with this code (and they programed the codes and should know what this means). Any help would be appreciated.
We have a belling gas hob. Intially when we turn on the control knob it gave a ticking sound even after it got ignited. then when we were turning on one burner it gave ticking sound in all burners . but...
take out the control knobs. clean the grease and food partilcles if any using hot water and dish washing liquid .if the washer under the knob is stuck, put it properly and put the control knobs back into it carefully
Jan 11, 2010 | Stainless Cooktops
Cannot calibrate pan sensors after changing right front element
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 29, 2009 | GE 30" Built-In Electric Cooktop - Black
One unit show fault code F153 before, now fault 160
May 29, 2009 | GE 30 in. Profile JP938 Electric Cooktop
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Error code F153
Did anyone ever find out the solution to this issues. I have the same f153 fault code and want to know how to solve this
RLA
Jul 17, 2008 | GE 30 in.JP950 Electric Cooktop
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
GE 30 in. Profile JP938 Electric Cooktop Logo
1,508 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
