Pioneer Model SD-P4571 Problems?
A Pioneer Model SD-P4571 projection tv. It works fine for a while then shuts off. You unplug it a few minutes and plug it in again and off you go. Then it may be a month, may be an hour before it happens again.
Any ideas of what could be wrong?
  • 552 Answers
It could be because of where you live.
Hi humidity, High temperatures where you live, etc.
Try placing a cooling source next to it, like a small portable air conditioner and even a fan.
Also, please try installing a GFCI outlet AND plug a surge protection outlet strip for all components and tv.
Any spike in your electric circuit, for example, a refrigerator starting, a furnace running etc. can cause the tv to turn off.
Regards,
Yalmer
Posted on Mar 13, 2008
6ya staff
SOURCE:
How do i convert my 1998 pioneer projection tv (model) SD-p4571, Serial Number oj3608792, over to digital reception? Is there a certain usb or cable inputi need? If so, is there a manual or simple guide...
Was the TV plugged in and turned on? If so you probably got a power surge and blew a fuse if you're lucky. Also check and make sure the wall outlet is energized. Something could have happened when you switched power sources. dhgill1949
Jun 04, 2011 | Televison & Video
Pioneer 5065 tv
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement. Good luck
May 25, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
I have A pioneer sd-p4571 projection big screen tv and the picture is cloudy how do i fix it
remove the screen assembly and clean the lenses the mirror, and the back of the screen. What you have is dust on the inside.
Sep 29, 2008 | Televison & Video
Pioneer SD-p5073-K Shuts off
it is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Aug 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P4552 turns off immediately after turning on
Good Day, vash4056;
Don't dig a hole yet I'll will have to some more research.
Okay?? big IRISH.
Aug 07, 2008 | Televison & Video
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
PIONEER TV MODEL #SD-P4571-Q
You can go to www.pioneerelectronics.com to see if a download is still available . Or just run the audio - video to the back of the set via input 1 or 2 . This should get you going . Good luck
Feb 29, 2008 | Televison & Video
Electronic schematic for Pioneer sd-p4571
· http://www.eserviceinfo.com/most_popular/list_5800.html
· https://www.manualsparadise.com/Sho...model=M31429247
· https://www.completeservicemanuals.com/panasonic/digital-camera/lumix-dmc-fz5-service-manual/prod_86.html
· http://www.user-service-manuals.com/Sony/UP.shtml
· http://www.schematicsforfree.com/
Jan 17, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
