Question about Toshiba 57HLX82 57 in. Rear Projection Television
Double images I just got my tv repaired and the it has double images of writing. The tech said it was a convergence problem and it can be corrected using the remote. I just moved and the remote is packed in a box somewhere as we always used the satelite remote. Is he right? The problem they fixed was a jumpy picture on the non-HD channels and I saw in your notes that the part they replaced caused that problem. Is there any way I can fix it without the remote? If I cannot find the remote do you know where I can get another? Thanks KH in PR Keninindy@aol.com
  • Toshiba Master
  • 8,617 Answers
You will need the remote to adjust convergence.
Posted on Mar 13, 2008
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Our Sony Projection TV has the red color distorted
Double picture symptom shows tv got problem with convergence out section and most probably convergence out chips would be replace to fix this issue.
Though its job of qualified tv tech to replace convergence out chips yet I can provide you helpful info if you are handy with electronics stuff repair and can replace parts in circuit board as soldering work is needed with proper tools to repair tv.
Thanks.
Mar 14, 2010 | Sony KP-51WS510 51" Rear Projection...
Tv is showing double vision with red being the second image
This is due to convergence out chips failure, replace convergence out ICs in TV to get converge picture.
If you are handy with electronics stuff repair and want to repair TV by yourself (soldering work is required) then let me know exact model number written at back of TV to provide you more technical info OR ask local tech to fix it.
Thanks.
Jan 07, 2010 | Panasonic PT-47WX53 47" Rear Projection...
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
EVERYTHING IN WRITING IS DOUBLE AND THE PICTURE IS DISTORTED
Hello Tim this is a very common problem with the projection tv set, the problem is coming from the convergence board with faulty ICs that have to replaced in order for your tv set picture to work properly,they do sell convergence repair kits for your tv set but i would not recommend this the reason being is that if you make a mistake while changing out a component your whole tv set is gone not going to work anymore so for this i would recommend for you to call a near by tv repair shop and have a tech come out and change this ICs for you, after you change this ICs from the convergence board your tv set should go back to working normal on the link below you can check out how a convergence board looks like thank you hope this helps.
http://bestbuy.partsearch.com/content/pages/tv-convergence-boards.html
Aug 29, 2009 | Sony KP-46WT500 46" Rear Projection...
Picture suddenly distorted, green and violet lines
It is convergence out ICs failure problem and you need to replace two ICs in convergence board/ section in TV.
If you are not familiar with TV repair then call qualified TV tech to fix it.
Apr 15, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Double image
Problem seems in convergence out section.
TV needs Convergence Out ICs replacement.
If you have TV repair experience and know good soldering work then you can give it try OR get help of qualified TV tech to fix it.
If you need further help, let me know.
Dec 30, 2008 | Hitachi 51GWX20B 51" Rear Projection...
DOUBLE IMAGES
there is a problem with tthe convergence section this is something a tech can do
Sep 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 57HLX82 57 in. Rear Projection Television Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
