Question about Philips 150B3T 15" Flat Panel LCD Monitor
Green Light Blush then nuthing on the screen
Hello All
I have Philip LCD monitor. There was no light indicator.. I thought may be it has problem with the power cable. I changed the cable But it is still same. whenever i turn it on, it shows the green light for one second and then it does not show anything ..I mean nuthing on the screen and no lights indicator
Can u please help me
Thank u
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPUGreen Light Blush then nuthing on the screen - 1.gif and monitor. After it went blank, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Posted on Mar 13, 2008
Acer al1912 green power light keep flashing with no picture
The black display and blinking power light indicate a failure of the power supply filter capacitors. This is a common issue on LCD monitors after a few years of use. The repair is easy to do you will need to open the unit and replace the bad capacitors on the power supply board. Here is a link to an article explaining what capacitors are and how to locate the one that failed on the power supply board.
http://www.ccl-la.com/blog/index.php/capacitors/
Sep 26, 2012 | Computers & Internet
The green light indicating power is blinking on and off and nothing is showing up on the screen.
when the green light is flashing it means it's not getting a signal from the computer..
1. try toggling through available sources with the source button on the monitor.
2.check all cables leading from the pc to the monitor.
Apr 02, 2010 | LG Flatron L1718S LCD Monitor
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
Monitor will not light up, black screen.
what is your monitor is it lcd or crt? is the power on indicator of the monitor lights up? which is usually a color green, if it lights up, try to reset the vga cable of your monitor to the video card of your pc and this time do it tightly but not too tight. But if the power on indicator does not light up, the problem lies within your monitor. Have your monitor be check by a professional technician.
http://lcdmonitor-repairsecrets.url-Go.com
Oct 05, 2009 | ViewSonic VA520 15" Flat Panel LCD Monitor
Model HU171D Hanns.G... Monitor is on but blank screen appears...
I think the data wire may be disjoined in the Center. try to replace the data cable and reply me.
Aug 19, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
The screen is black even though the green light is on
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
E172FPb Flat Panel Color Monitor black screen problem
Your backlight inverter inside the monitor is out. If you are comfortable soldering you can repair it yourself. We have a step by step repair guide on our web site at: www.ccl-la.com/LCDrepair5.htm
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Monitor blackout thought green powerlights on
When your dell e173fp lcd monitor black out, the led power light are still green color. Normally, this will be the inverter board or ccfl lamp problem. May i know, after this monitor black out, do you have try use the torch light to see any display on the screen? (sometime the display are darkness only and not totally no display, you need see it clearly). Any details on repair lcd monitor please goto this website, http://www.fastrepairguide.com
Sep 01, 2007 | Dell E173FP 17" LCD Monitor
Philips 150B3T 15" Flat Panel LCD Monitor Logo
88 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
