Question about Kenwood KDC-MP235 CD Player
Bad reception I use to be able to get all of my favorite radio stations in clearly. Now I'm only able to recieve about 3, 4 if I'm lucky, FM stations! My car antenna is out all the way and nothing else has changed with my car. Just suddenly happened.
    Sergeant:
  • 300 Answers
I see you've already read the "Troubleshooting" section of the manual! The only other things I can think of to check would be the actual connection between the radio (aka head unit) and the antenna. It's usually just a press-fit connection behind the radio, but if it's loose, corroded, or is touching some other metal, it could affect the reception.
There's also the small possibility something changed at the transmitter tower for the radio station. That happened in my area once, where they changed the direction in which most of the signal power was being broadcast. Westside reception got better, eastside reception got worse.
Posted on Mar 13, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
How do I change my cd clock radio to AM
probably doesnt have AM option. You have high quality CD sound and high quality FM sound, they don't let you have bad quality AM. Having said that it does.
LISTENING TO THE AM/FM RADIO 1.
Press the ALM OFF/SOURCE button to select the FM or AM mode.
2.
Press the
/MIN button or
/HR button step by step to tune to the desired radio stations.
3.
Press and hold the
/MIN button or
next radio station in the direction of the search. The search operation simply finds stations with
strong signals. Stations with weak reception can only be tuned in manually
THIS MANUAL IS FOR THE 201
Onn ONB14AV201 Product Manual Product Features View
Jul 09, 2017 | Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
Emerson rp 6247 radio AM stations does not come in clear
Try moving the telescopic antenna around in different directions until you get a clear reception. If that doesn't work, try moving the whole unit (radio) to another location. Make sure you are using the tuning knob to switch between stations. Moving it to a different location may be the best thing because the radio antenna may be received in frequency waves from another electronic device (i.e. a television set, another radio or in microwave) which is causing a reception to be poor.
Mar 21, 2011 | Emerson RP6247S FM/Weather/AM/TV Radio
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
How good is fm tuner reception? We live approx 50 miles from transmitters and have trouble getting clear signals. Is Bose just good sound quality, or does tuner provide superior reception?
I live in Vail Az about 110-120 miles from Phoenix Az I can pick up 60% of the stations decent. The power cord acts as a fm antenna. Plus this Bose Wave CD/MP3/FM
Aug 16, 2009 | Bose Wave Radio
No fm reception
look for a button called mode and press that, it should switch it to fm narrow (communications) or fm wide ( fm broadcast stations) or am
Aug 13, 2008 | Icom IC-R5 Handheld Scanner
Not recieving fm radio stations
if you can get am stations the problem is in the radio's tuner if you cannot get am stations either your antenna is bad, if this helps you please give me a good rating if not please e-mail me at merle840@aol.com
respectfully, m.merle
Apr 17, 2008 | Jensen CDH-1000 CD Player
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
Kenwood KDC-MP235 CD Player Logo
314 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
