Question about Ovens
IT WON'T STOP BEEPING!
My range is beeping, sounds like the timer going off, but it will not let me cancel or use the main oven. All of the top elements work but i have to unplug it to stop the annoying sound. Please help if you can. Ms. Love
This thing is crazy.it has a mind of its own.the START light will flash and it will 'BEEP' anywhere from 3 to 20 times,and then stop for a few minutes.this goes on for hours. It will do this about twice a week. If i use it ,it will stop, but after i turn it off it will continue (if it wants to).Sometimes using the pre-heat or cleaning cycle will fix the problem but only sometimes..this thing has a mind of its own
model#MEF352CGSA i cant find it here
  • 4 more comments
  • zoo-poo Mar 13, 2008
    My Kenmore oven WILL NOT STOP BEEPING!!!! Every time i use the convection feature or an element with the oven it shuts down and F11 flashes on the display and it wont stop beeping until it is unplugged. It is extremely annoying and very frustrating when trying prepare meals. Can somebody help me?????
    Shelly
    slwalsh@rogers.com
  • Anonymous Mar 21, 2008
    my oven wont stop beeping every minute
  • Catherine Maclead Apr 24, 2008
    I have read the maual for my inherited Jenn-Air self-cleaning Radient Bake and Convection Wall Oven Model W276. I have tried to use function pad correctly and read the timer instructions. To stop the maddening beeping, I have taken the steps to cancel the timer. No deal! Help!
  • jes315 Jun 29, 2008
    Unit statred beeping on and off for over aweek. It would stop and restart. Every thing seemed to work ok until I tried to use the oven. NADA. The broiler worked but clock did not. Finally it stopped all together and gave and F7 EA and EC fault codes. This is the second unit I have owned the first was also 16 months old and the wqarrany was out. It was going to cost over $400.00 to fix. I just assumed it was a lemon so I found another new one from Home Depot for $360.. Now 7 months after warranty expired just l ike the other it also failed I this designed obsolescence? What is wrong is it the panel or the ECR? How about a new part that fixes the problem at reduced cost
  • Stuart Connall
    Stuart Connall Oct 28, 2008
    I have the same problem and sometimes it will stop for weeks if I turn the oven light off. Today it is acting up again and nothing will make it stop...Oh, it just decided to stop...until the next time it starts driving me crazy.
  • lcharlton25 Dec 06, 2008
    My oven timer just started beeping and won't stop. I can't switch back to the clock mode.
    New Friend:
The relay to your beeping must be bad. It could be due to moisture build up for some time. The beeper could also be connected to an electronic board. In most cases that happens to a board when heat and cold mix perhaps shorting the relay to cause it to stay stuck allowing your beeper not stop beeping. Relay should be attached to the switch panel of your stove.
Posted on Apr 28, 2017
    New Friend:
  • 19 Answers
I'f the above fix doesn't work, here is the control model replacement
https://www.midwestapplianceparts.com/index.php?main_page=advanced_search_result&search_in_description=0&zenid=uo8t1t4u923uk8gg1m7bu7cmr1&keyword=316101103
Posted on Apr 25, 2017
    New Friend:
I had that issue with my oven but turned it off at the meter box for 30 mins and it fixed it. It seems to be caused by electricity surges/power outages
Posted on Apr 09, 2017
  • 159 Answers
SOURCE: Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Posted on Jul 20, 2007
Powerman
  • 68 Answers
SOURCE: Ge Electric Double oVen
This may be related to a problem I have helped others solve. The solution is available free at my website. I have at last count helped over 1000 oven owners with a similar problem. http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf Hope it works for you too.
Posted on Aug 09, 2007
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
SOURCE: F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Feb 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: f0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
Posted on May 26, 2009
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
What is error code F1
Here's a list of error codes for Whirlpool oven/range. Whirlpool Range Fault Codes
Sep 21, 2014 | Whirlpool Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
Apr 21, 2014 | Whirlpool Ovens
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
Read more :
Jan 19, 2014 | Thermador Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
My jenn-air oven keeps peeping and displaying the message -F 1- . if I push the cancel/off pad the beeping will go away, but sometimes it will start beeping again shortly after. please advise.
30" No.W46K03 or 318200413 S/C range.
When the bake is press and the timer is push to 400oC it instantly dropped to 100oC and takes 4hrs. to come to 250oC instead of 400oC . Please advice me
Feb 05, 2010 | Ovens
Error f1 and beeping sound when the oven is on. Heating non stop.
Your digital panel may still be under warranty. It may be worth your while to have a tech look at it. Something else is going on here.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
Beeping sound
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Mar 22, 2008 | GE JKP28 Electric Double Oven
Ovens Logo
728 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
