Question about Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 random shut off while printing
Lexmark X6170 all-in-one printer, randomly turns off in the middle of printing a page, may print several pages without any problems, then will shut off while printing the next. did once shut off while not printing anything,
turns off for aprrox 5-10 seconds, then turns back on by itself, but does not continue to finish printing. no error message has ever been given, called tech support, sent me a new power cord which did not solve the issue,
  • Anonymous Mar 21, 2014
    total power shut down
    Genius:
  • 2,035 Answers
I think the power saving mode is on your printer ?try setting to off mode or 2 hrs mode...
Posted on Mar 15, 2008
I have a brand new ink cartridge in my printer. It printed the test page ok. When I try to print envelopes, it always says paper jam (there is no paper jam) the envelopes just wont feed. It's a Lexmark...
Make sure to set the correct paper setting on the printer or the Lexmark software before sending the print job. Adjust the printer's paper guide to the correct envelope dimension.
Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
How to run a report from Lexmark X6170 fax
Please follow these steps to run a report on your Lexmark X6170. From the printer operator panel, press Fax to enter Fax mode > press Options repeatedly until Print Reports is highlighted. From there you can print an activity report, send log, receive log and fax settings list.
I hope this helps.
Nov 07, 2011 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
I am unable to find color ink for my lexmark x6170. Additionally, are all the inks the same (quality)?
Lexmark X6170 uses these two ink cartridges: -
Black Print Cartridge (18L0032E)
Colour Print Cartridge (18LX042E)
It is highly recommended that you use the original cartridges as the cartridges and ink vary from printer to printer.
However, if you are unable to find the cartridges, you may look for refilling option.
CreativeTECH
Jan 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have a Lexmark X6170 all-in-one printer and a Windows 7 system. Apparently there is not a driver for this. It says to use the vista (32 bit) driver which I have. Problem is, when I print something it...
If you are upgrading to Windows 7disconnect USB and Uninstall Printer driver already installed, first. Then use the Vista Driver for installing again........It will work.
Try this and do get back if it does not help..........
thanks
Mar 05, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 printer color cartridge but wont print
COULD BE COLOR CARTRIDGE IS DRY ! have it check to an OFFICE MAX or WALGREENS
Oct 30, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 stopped printing text will only pint images
First, print a test page from the printer's menu and see if the black lines and text look okay on that. If there is no or poor black printing, you need to replace the black cartridges or try cleaning the cartridge's nozzle with rubbing alcohol. If that looks fine you need to check the printer's settings in its properties on the system lift of printers.
Oct 01, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 will only copy l/4 of page as a copier but copies full pages from the computer
check the properties and page settings before you print you may find your page settings are incorrect to what you want. Set to all pages, make sure print colour documents black is unckecked, make sure no other settings are telling it to print other than what you want. Post back if no good.
Sep 03, 2008 | Lexmark X6170 All-In-One InkJet Printer
X6170 Prints only one page then freezes
drivers are most likely not up to date, especially if you used the old ones. Gotta go to lexmark, and get the latest Vista friendly driver. I recommend the highest quality one, with the most features(so that Vista won't spit it out again).
Feb 06, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 alignment problems
Is the ink generic brand or lexmark brand?
Nov 13, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
243 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
