The above kit can only be used on models with a metal liner and will not work with the plastic liner models. Making sure the freezer temp is at 0 is critical! If it is below zero then this could be the cause. If it has a plastic liner and it freezes again after defrosting then the only solution is to replace the freezer door per ge. Hopefully you have the metal liner and can use this kit
Water is frozen inside the water tube that runs inside your freezer door. If you empty out the food in the door, you can use a hair dryer on medium heat to warm the frozen piece so it loosens enough the dispense out. Every 5 minutes, close the door and check if water dispenses. It takes between 15-30 minutes.
GE makes a dispenser water tube heater that attaches to the top of the dispenser tube to prevent frozen tubes. The part is WR49X10173. Check to make sure it is compatible with your refrigerator. Amazon and Walmart.com sells the part. Good luck!
