I have a Ripspeed DVD-730B head unit for my car. its all installed but when trying to play a dvd it displays a message sayin: do not watch while driving and then only plays sound, no picture. how do i get it to play.
If the unit was installed with a handbrake lead properly it will only get picture with handbrake on,try taking that wire off and connect it to a permenant positive like the permanent live to the head unit,so the unit thinks the handbrake is on, or if it wasnt installed properly and that wire is somewhere else like a permenant negative then the unit thinks the handbrake is always off hence no picture while driving,hope this helps :-)
Posted on Mar 16, 2008
Well simple just go to the setting then parking mode and then turn parking off ok then image will be on all the time
Posted on Oct 07, 2008
GREENWITE WIRE TO NEGATIVE WILL WORK AND FOR YOUR SETINGS YOU HAVE TU PUSH THE VOLUME BUTON FOR 2 OR 3 SECONDS IT WILL SHOW YOU THA MENU
Posted on Jul 07, 2010
What button do you press to get up settings for the parking mode button as i have lost the instruction for my 730-B
Posted on Aug 20, 2009
Hi im new, but had the same prob,..the parking brake wire definately has to have an EARTH!!!
Thanx
Posted on Oct 11, 2008
Is it positive side or negative side
different answers all around on here
i was going to put the hand-brake wire to the ignitioned power supply will this work?
thanks
Posted on Oct 10, 2008
It needs to be wire to earth not positive
Posted on Sep 29, 2008
I just wired the handbreak cable to the light in the glove box :P positive side
Posted on Sep 01, 2008
The lead must be copnnected to a permanent EARTH for picture to show at all times .
Posted on May 10, 2008
Drytyiufkgjklkj
Posted on Apr 06, 2008
Ripspeed dvd 730b settings
Description is too vague. If you are certain the speakers, power connections, and all wiring is proper, the radio is bad.
Dec 16, 2013 | Car Audio & Video
Hi don't have a vid i have a ripspeed dv720 it will play CDs but not DVDs it keeps coneing up bad disc any ideas
ripspeed are prone to problems, just a cheap equivelent for an in car dvd, most likely the laser is goosed
Feb 05, 2013 | Car Audio & Video
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Hi i have a ripspeed dv710 plays the radio fine put a cd in and theres no sound but timer goes up si a no its plying same on dvds you can watch the film but no sound anybody help??
it sounds like it was installed incorrectly. there must be amps in the car. when the dvd player was installed they hook up a blue wire on the back of the radio. its a power antenna wire . switch it for the blue white wire and youll be in buisness
Feb 04, 2010 | Car Audio & Video
I need help wiring a sub to a ripspeed dvd-730 cd player.because it has to aux-in wires but 1 sub out wire.
the phono out is the feed to the sub, if your amp has high input socket then run feed from normal speaker feed from head unit, or pop into halfords and ask the ripspeed specialist
Dec 22, 2009 | Car Audio & Video
Instruction manual and installation manual for ripspeed dv725
fitted the dvd player but no sound could u help
Jun 07, 2009 | Car Audio & Video
Ripspeed in car dvd player
I had a similar problem with mine I have just had a technical fault with mine and the only solution i could find was through halfords. If its under warranty they send it off to their supplier AEL to solve. If its no longer under warranty like mine, they send it off at an initial £60 cost which could escalate if the problem is larger.
Feb 12, 2009 | Kenwood DV-605 Multi-disc DVD Player
MY DUAL IN-DASH DVD WON'T LOAD ANY DVD OR CD.
OK so be said the player will not load the CD...how in the world is he going 2 clean the lens if the player won't load anything? I'm just sayin...
Feb 03, 2009 | Dual XDVD8181 Car Video Player
Ripspeed dv-725 problem when trying to play dvd it says attention, do not use this function!
Your Player doesn't support DVD/CDs that are burnt on High Speed DVD/CD Recorders. To resolve this, you should either burn DVD/CDs at 4x(DVD) & 24x(CD) or go for a newer, higher end DVD Player.
Jun 25, 2008 | Televison & Video
Ptid-5300
Its illegal to watch a dvd/tv when the vehicle is moving so the manufacturer disables the function.. Usually by connecting a cable to your handbrake indicator or to your vehicle speed sensor VSS.
Youll have to find out which one it is. You can then find out how to disable it. JVC's normally ground the H/brake cable
Apr 04, 2008 | Power Acoustik PTID-900 Car DVD Player
Televison & Video Logo
1,985 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
