Question about Linksys Wireless-G WRT54GS Router (e125894)
Wii connection issues.
Well I bought a Linksys Broadband Router so I could connect my Wii and DS to the internet and play online...and it woked great on the DS...but not so much on the Wii...on the DS the games play with out any issues...but for the Wii...whenever I try to play a game online it keeps losing connection...could a firewall be an issue?...please if somebody could help me out...I'm really confused.
    Scholar:
  • 141 Answers
You can check if the problem is with the internet connection going to the Wii or just the wireless connection.
When you loose connection, check the Wii's ip address. If it does not have an ip address(or ip is 169.xx.xx.xx) that means that the Wii is disconnecting from the wireless network. You can then try other wireless channels on your router.
If the Wii is still getting an ip of 192.168.x.x, that means that the problem is the internet from the router. You might need to forward ports on the router for your Wii.
Posted on Mar 13, 2008
Can I play playstation 3 online with a E1000 cisco router?
You should be able to connect to the Internet provided the PS3 wireless segttings is configured correctly.
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Aug 11, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How do i set nat settings for lynksys Wireless-G Broadband Router for xbox 360
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
Aug 10, 2010 | Linksys Wireless-G Broadband Router
I can connect the internet on my wii with this
**I m not able to find a snapshot of the router interface. But i ll tell you what all to do there
1) Disable the router's inbuilt firewall
2) Enable DMZ for your Wii's IP address; assign this same IP address on your Wii manually
3) Change the bandwidth of wireless to 20/40MHz
This will surely work
Jan 17, 2010 | Linksys WRT54G-TM Wireless Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Cannot connect my ds or nintendo wii to buffalo wca gaming access
If as "wired internet " you mean HI-SPEED internet access then .... Follow the instruction as per this manual
Be Sure it's connected to your Hi speed Modem.
If you do not have Hi speed connection It will NOT work at all.
Dec 30, 2008 | Buffalo Technology WCA-T 802.11b Wireless...
No internet connection on web browser
The problem may be in the router itself, prehaps a faulty product. But I am more inclined to think it is the outdated copy of windows 2000 which you use. In my view 2000 was second to Windows ME in terms of faults, errors, recoginizing hardware, and what have you. I would take the router back to walmart and test with a new one, but if that does not help, then it may be time for you to upgrade. Have you tried getting the ps3 online even without the computer having an active connection? Give that a shot and if for some reason the ps3 grabs the signal then it is time to give in for sure man. And watch the router when you try to connect the ps3 to see if it even attempts to grab the wireless connection, the wireless light will start blinking rapidly if it does.
Jan 25, 2008 | Linksys Wireless-G Broadband Router
Please help
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
config your router by running the setup cd and that would fix your problem..
let me no know in case if you have any problems ...
Dec 02, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
I want fast help..how to get connection between linksys router and aztech modem
first check..
Step 1:
Step 2:
Step 3:
Step 4:
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Linksys Wireless-G WRT54GS Router (e125894) Logo
483 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
