Question about Olympus Camedia D-380 Digital Camera
D-380 smartmedia card formatting
Greetings Gurus,
I tried to download pictures from my smartmedia card and my computer somehow unformatted the smartcard. I was able to recover the pictures from the card using PC inspector. But now the computer can read the card, but the camera can't. When I put the card in the camera it keeps asking me to format the card. When I say yes, it says "card error".
How do I format the card to work in the camera again?
Cheers,
Carl
330-472-3055
[email protected]
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
There is something alled the CIS header on Smartmedia cards. If that is missing or damaged, any compliant Smartmedia device will not let you use the card. Many card readers are not Compliant and thus ignore the CIS block.
It is advisable to not try and "recycle" cards with a damaged CIS block by using them in a non complying card reader because of one of the reasons why the CIS block is there is to ensure something called the bad block table is present on the card as well. The bad block table maps the locations of bad memory cells and prevents writing to them so the card will apear 100% good. All cards have some bad cells from the factory even. Most likely the bad block table will be missing as well and your non complant card reader will end up writing over bad memory cells which will cause future read errors and data loss.
You would need access to a compliant Smartmdia reader that is compatible with the SMPREP (or similar) formatting utility to fix problem smartmedia cards. SMPREP fixes the CIS block and scans the entire card for bad memory cells and updates the bad block table.
Posted on Jul 22, 2008
SOURCE:
I don't know what happened but my pictures are gone and I don't know how to get them back! Please help!!?!
Assuming you didn't download the pictures to your computer ... and as part of the download option, you elected to erase/remove the pictures (after downloading them) from the camera ... and you have not done anything (on the camera menu) to "refresh" or erase the pictures, or reformat the storage media (memory card) ...
then ...
... if the pictures are stored in a memory card .... you can take that memory card out of the camera, insert it into your computer ( ... or use a card reader, inserted into a USB port) ... and see if you can recover the "deleted" data from the memory card ...
... if the camera only has "internal" memory ... connect the camera to your computer ... and when it shows up as a storage media, try to recover the "deleted" data from the memory card ...
You can (find on the Internet) and install and use various (free) software (on your computer) to recover "deleted" files on storage media (memory card, etc.), ... on a Windows PC ... like PhotoRec, PC Inspector File Recovery, Undelete Plus (or Undelete 360), Glary Undelete, Wise Data Recovery, Recuva Free.
Apr 03, 2014 | Cameras
How to format or unformat memory card on IXUSi camera I need to know how to format and unformat the memory card I can't see the pcitures as it is showing no image on the screeen Regards C Robertson
to format a sd memory card, you can insert the card to computer or camera, and select the format. To unformat a sd memory card, a data recovery software can help you.
Are you in a dilemma as to whether to format your SD card or not? If you don't format the SD memory card, you cannot use your SD card any more, and you cannot transfer files from SD card to other devices. If you format the SD memory card, you will loss all the files like photos and videos on your SD card. Follow the link you can get the answer.
Jun 28, 2010 | Canon IXUS 80 IS Digital Camera
Format 32mb smartmedia in FAT12
Hi friend,
ok you can try to format on windows xp.
Follow these steps:
1.Open Control panel
2.Open administrative tools
3.open computer management
4.then click disk management
select the drive and try to format as per you requirements . note that you can also delete the partition and create new..
ok
Regards
Uttam
Jan 13, 2010 | SanDisk 2GB microSD Memory Card
Fuji FinePix Z - my camera was working fine one minute then the next time i turned it on it said "CARD NOT INITIALIZED!" and it won't let me take pictures or view my pictures. HELP! how do I fix this? Can...
You may try some photo recovery software to rescue the files on your digital camera, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Aug 20, 2009 | Fuji FinePix A850 Digital Camera
Memory cards
The largest memory card that the camera can support is a 128mb smartmedia card. The card will hold approx 257 images when set to HQ mode.
Dec 26, 2008 | Olympus Camedia D-380 Digital Camera
Format-Pictures Gone
I hit the Format button. Now all of my pictures are gone. Can someone please help!
Oct 22, 2008 | Pentax Optio E10 Digital Camera
Unformat
I have a PMD660 as well and from time to time a memory card will become "corrupted". During a recording last evening the battery ran out "prematurely" and when replaced, the 660 had the unformat error. Fortunately the card was readable in my Hummingbird card reader.
Normally when I have had UNFORMAT problems in the past I would just FORMAT the card with the computer and the 660 would then be happy with it. Not this time! The 660 still stubbornly displayed UNFORMAT! This time I ended up having to use Partition Commander to wipe out the partition on the card and then DISK MANAGEMENT in the XP's Computer Management program to re-create the partition and format FAT32. Normally when you FORMAT all data is lost so this would end all hope of recovering data from the card.
In the case of hoping to recover lost recordings I would have tried QUICK FORMAT and then tried to "recover" the data with a program like Partition Magic or Partition Commander or some other program that could re-link the blocks and create directory entries.
Jul 04, 2008 | Marantz PMD660 Digital Voice Recorder
SmartMedia - how to download images without USB cable
get a new cable. or a new card reader. i prefer card readers as i can take my camera around to various events, and if a friend wants an image, he can attach the reader to his computer (if nearby) and get what he wants.
are you sure your computer can directly read smart media cards?
possible it does, but not that common unless its fairly new.
mark
Nov 01, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Download the images
In order to access images stored on the internal memory, the SmartMedia card must be removed. Once the card is removed, follow the procedure used to download images stored on the SmartMedia card.
Aug 31, 2005 | Olympus Camedia D-380 Digital Camera
SmartMedia card
The camera has a Memory Back-Up function located in the Play menu. Please refer to the Reference Manual on the CD-ROM for this procedure.
Olympus Camedia D-380 Digital Camera Logo
223 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
