FixYa.com
Tags:
Nikon Speedlight SB-600 TTL Flash
Sb600 wireless mode not working...
posted by M-Jooo on Mar 13, 2008
hi
i have a nikon d70 and an sb600 flash. all was working well until i tried to use the sb600 in remote mode. worked very well for a couple of months then started becoming sporadic. and now, it works for the first 2/3 shots then nothing. even the built in flash stops working. so i have to shut off the camera and leave it, until the next day when the same happens (ie works for the first few shots then nothing).
all the settings on the camera is fine, all the settings on the flash unit is as it should be.
the wireless facility on the sb600 is a fantastic asset and i would use it a lot more if it worked. just very frustrating that i can't seem to get a solution to this problem anywhere.
appreceate any help!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 15, 2008
Not Rated (0)
MarkDay
Rank:Guru Guru
Rating: 87%, 53 votes
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Flashes problems?
LCD DISPLAY FLASHING
lcd display on sb-600 flashing.... Answer This...
flash sb600 flash
the foot that connects the... Answer This...
Flash starting firing slow
Checked batteries, and camera... Answer This...
flash gun failed
After working for 2 years... Answer This...
nikon speedlight sb 600ttl
drop my flash will go to ready... Answer This...
Repair Service
Find Flashe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
