Question about LG 42LB5D 42 in. LCD Television
Hooking up a DVD player to a LCD TV
I have LG LCD TV and a DVD recorder...how do I hook up the DVD player to record programs from TV? Our satellite reciever is hooked to the TV with a HDMI cable. Our DVD recorder is hooked to the TV with componet cables. How can a get the correct connection to record programs from TV? Our TV has a menu that has to be selected on which cable is being used...HDMI for satellite viewing and componet for DVD viewing....please help!!
    Scholar:
  • 43 Answers
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Posted on Jul 09, 2017
charcois
  • 763 Answers
SOURCE: TV CONNECTIONS
if your cables are not compatible or incorrect ends then try to buy an adaptor to fit to the right connectors. so you will be able to connect each ends.
CHARCOIS
Posted on Sep 16, 2008
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
  • 40 Answers
SOURCE: i have an lg 50pg20 and i cant hook up my ps3 using the hdmi cabl
Make sure the xbox display settings are not defulted to 480. Have you tried using the component hookup instead? Theres really not that big a difference in quality between the two if your settings are correct in the xbox display menu.
Posted on Jun 19, 2009
SOURCE: I have an Lg plasma 42
try changing the cables to s-video or hdmi to see if the problem solves. It could be defect or reverse component cables
Posted on Dec 26, 2009
  • 3 Answers
SOURCE: LG 42 LCD TV HDD initialization in progress message
Change the hdd or remove it then connect it to PC and do for it format , it will work .
Posted on Nov 14, 2010
Do I need a special cord to record from digital tv
No,u can use the R,Y,W colors AV cable,the same hook up as a VCR recorder in the past.Read ur instructional manual,find out, if the unit can take HD hook up,use a HDMI cable for the hook up.Yes,buy a HDMI cable hook up to ur LCD or Plasma tv.Best result and the use of the recorder and LCD or Plasma digital tvs.
Oct 02, 2010 | TruTech TT1620 DVD Recorder
I am trying to connect my DMR E55 DVD recorder to my Viera 32LX TV and take the satellite signal from the TV and the recorder is reading nothing. I am using optical cable and a SCART. What am I doing...
To hook up you need to go from the satellite box to the recorder then to the TV. If you do that then you should be able to record the show on Tv. You can get the manual on the link below. Page 7 tells you how to hook up.
http://www.hollywoodstudiorentals.com/uploads/030708__Panasonic_-_DMR-E55%5B1%5D.pdf
Dec 30, 2009 | Panasonic DMR-E55 DVD Recorder
YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
Can't get to recorded programs
Check and make sure you have the DVD Recorder hooked up to the TV. I think you have the Cable box or Satellite hooked up or else you could not record. So there is a second set of outputs on the back of your DVD Recorder, Buy a set of RCA jacks and plug them into the Yellow,White, Red Plugs of your DVD Recorder, Then plug the other end into your TV in either L1 or L2 inputs, whichever ones are free.
May 12, 2009 | Panasonic DMR-E85H DVD Recorder
How do I hook up the recorder
Hi....
Take the output of the Satellite box to the "In from antenna" or "in from cable" then out to TV from the VCR to the TV.
TV should either be on 3 or 4 depending on what the satellite box is set for
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Recording tv programs etc
I had same problem. With mine i could record wo the digital cable box but not with it hooked up. Would love to get some info about it.
Apr 27, 2008 | Sony SLV-D350P DVD Player/VCR
LG 42LB5D 42 in. LCD Television Logo
359 people viewed this question
Computer Repairing
Computer Repairing
