Question about Kenmore Elite 45986 Front Load Washer
Wash.machine won't spin
i have a zanussi washer-dryer. (wjs 1397w)
it would turn, but would not go into the spin-cycle at the end of the wash-cycle.
the pump would run for 10 minutes, trying to empty an already empty sump, then the spin-cycle would end and the machine would turn itself off.
i unplugged a 2-prong lead that is fixed to some kind of sensor attatched to the bottom of the drum to see what would happen.
it now spins fine, but races through all the wash programmes at 5 times normal speed.
anyone have any idea what's going on? what is that sensor, and is it broken?
(plus, any idea where i could view a diagram of the workings of a modern washer-dryer??)
  • todc Mar 13, 2008
    drum won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Posted on Jan 15, 2009
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
My zanussi washer dryer wjs 1397 w drum is not turning
It is most likely that the drive belt is broken and needs repalcing, If you remove the rear panel it will be obvious if it has broken *** there will be a lrge flywheel attached to the drum and no drive belt going to the motor, near the bottom of the machine. These are easy to obtain from any domestic appliance spares store or mail order. They are also very easy to fit.If the drive belt is in place and is reasonably tight (taught) then you may have an issue with the motor. clutch or brake.
Oct 12, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Wjs 1397W. The water goes in OK. The
It was a bad joint on the motor control board. It was well burnt on one of the relay connections. I assume that the machine senses when the drive starts and then stops before changing the relays. Of couirse it only wend in one direction and was waiting for it to go in the opposite one before proceeding.
Jul 09, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS 1665 W Dryer
Your heat stats! or element!are faulty remove top to check them a meter would be usefull to check them,Advantage is! there easy to see stats!get back if you need to !or let me know!
Nov 11, 2007 | Zanussi FJS1225W Front Load Washer
Settings dial has broken on my Zanussi WJS - 1397W
You can go to this site and find/order the parts to fix it. It looks like the top of the machine just pops off (held down by clips) which then exposes the control panel and allows access to fix. Hope this helps.
http://www.espares.co.uk/diagram/washing-machines/zanussi/wjs1397w/p/1085/332/0/407647?ed=3912
Oct 27, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Aug 04, 2006 | Zanussi FJS1225W Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
235 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
