Audio no continuity in one speaker
  • Anonymous May 02, 2008
    no center speakeraudio
No centre channel sound
Posted on May 05, 2008
SOURCE:
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
Speakers stopped working suddenly? how can i fix iy?
Hello
A sudden stop of sound output while the set works denotes either its speaker or audio output IC damaged. Check the speaker first by using a multimeter for its voic coil continuity. If speaker is OK, the fault is surely with the audio output IC. It should be replaced with same type and number. It is a semi-skilled work, you have to open your tV, locate the audio output section. You must have knoledge in electronics to do this work. OK.
Dec 18, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Sharp LC-60LE810UN. the sound all of a sudden cut out on the tv. everything on the tv seems to be working just fine. but there is no volume at all.
hi,
You have to check three things.
1. Check is the mute function is ON or not. For that press the mute button on the remote.
2. Check the speakers of you tv. For that you have to open the tv. For testing the speaker you need a multimeter. Check the coil continuity of the speaks. it should be 4 ohms or 8 ohms. If there is no continuity then change the speaker with a new one. If the continuity is ok then
3. You have to check the audio output amplifier IC ( integrated circuit). For finding out the audio amplifier ic which one it is, just follow the wire from the speakers. Its other end will ends in the socket near the audio output IC. It will be fitted on a aluminum heat sink (radiator)
To replace the IC you need soldering ion,desoldering pump, solder etc.
the part number will be written on it. you have to purchase the same part with the same part number.
ok
Apr 27, 2011 | Sharp LC60LE810UN 60 in. LCD TV
How many watts is it n does it sounds good or no??
It's 125 watts continuous @ 4 Ohms. As for how it sounds, it's jl audio, it sounds good and is a solid speaker speaker.
Mar 22, 2011 | Jl Audio 10W0 Car Subwoofer
One speaker doesnt work the other ones poor
Assuming its a PC:- The problem may be due to the audio part. Try different music files or sound sources. - If the problem persists, on a windows system, go to Control Panel>Sounds and check & control the settings there. - If continues, try a headphone/earphone. If the audio is still not good on different audio sources, try reinstalling the sound drivers. If the audio is good, check the cabling and connections of the speakers (between speakers and PC, between two speakers and the power line) - If after all, the audio is still bad ( and headphone sound is good), the speakers have a malfunction. Try the nearest computer fixing service.
Mar 10, 2011 | Computers & Internet
Speaker quit working no sound, no continuity after the crossovers i have incus gfs-5 speakers
If there is no continuity at the speaker terminals (with the speaker disconnected) then the voice coil is open and the speaker needs to e replaced.
Feb 05, 2011 | Audio Players & Recorders
It does seem to be getting a power sound from my computer. When I plug in the jack to my laptop it does not make any sound to the logitech speakers and the sound continues to play from my laptop speakers.
You need to change the default audio output device in the audio control panel and restart the application (e.g. Media Player) you use to produce the sound.
Feb 07, 2010 | Logitech X-240 Computer Speakers
Audio not working i can access only my head set .i can hear song only through head set only when i plug out my audio device speaker notworking.no problem for hardware.before i can hear song through only pc...
Double-click the "sound" icon (bottom-right, beside the Windows "clock") to open the "mixer" application.
Be sure that you have not "muted" your external speakers (not the internal PC speaker).
Sep 10, 2009 | Compaq Computers & Internet
ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Dec 21, 2008 | Performance Teknique ICBM-Digital Car...
 Grubhead
Grubhead
Marvin
Marvin
