Question about Panasonic PT-47WX49 47" Rear Projection Television
Sudden pink hue to faces
Last night, all of a sudden our very reliable Panny has everyone's face looking really rosy... I went into the convergence menu, and everything seems to be working there. Our cable has an info box that you can pull up at the bottom, and it is white, but other things are off hue... This has been a very trouble free tv for us, but with very limited knowledge and ability, I'm afraid this problem may be beyond me. Any advice would be welcome. Thanks, Grover
  • Grovercxl Mar 13, 2008
    Dropped the color all the way down, and the picture is black and white... Looks kinda cool, but I'm sure the wife would not appreciate the look. Thanks for the reply... Grover
    President:
  • Panasonic Master
  • 1,779 Answers
It sounds like you lost your green, try turning down your color all the way and see if the screen is B&W, if it is then you have a problem in the ry-by-gy processor. If tthe screen is not B&W then I would suggest the Green video driver on the green CRT is bad or in that area>let me know!
Posted on Mar 13, 2008
There is a sudden change in the hue of my lcd- acer aspire 4740
It can be an issue with the display cable or the LCD panel itself.
U will have to check with a local tech.
May 31, 2010 | Acer Aspire 4720 Notebook
All of a sudden we got a pink screen on our Sharp Aquos TV last night. What does it indicate?
Most likely you have a faulty inverter or CCFL lamp. The CCFL is a fluorescent lamp that is the LCD backlight and the inverter board is similar to a ballast transformer. CCFLs often go pink when failing. The lamp is probably a $50 part and the inverter around $100.
Oct 07, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Pink Screen
This needs to be returned to the Vendor or Sony Direct for replacement
Jan 14, 2009 | Agfa Cyber-shot DSC-W150 Digital Camera
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Bent Picture at top and bottom
You have bad convergence amps.The fluid may need to be changed if the picture had a hazey look to it before the convergence went bad.
Dec 13, 2008 | Philips 60PP9202 60" Rear Projection...
Red gun suddenly went wacko
Red Convergence IC bad.....small circuit board by itself up
above main boards..........replace both IC's for reliability...
STK392-040.........DO NOT USE GENERIC IC'S ! I use only
PANASONIC brand = no re-calls !!
Re-align when repair complete............T.
Jan 28, 2008 | Akai PTH5498 54" Rear Projection...
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Picture problems
The convergence amps have most likely failed. This is the number one leading cause for the symptom your describing and the most common failure on that unit.
Your Tv take two STK392-120 Sanyo Ics for convergence amps, located at Ic7404 and Ic7405 on the board and mounted to a rather large aluminum heat sink. In addition you will most likely have to replace R3159 and R3160 (6.8 ohm 1w) resistors and test the remaining low ohm resistors for change in value.
A shop would really be earning their money on this particular unit if they charged $400 - $500 for the repair. It is an extremely difficult set to work on and there are a number of little problems that can reach-out and bite when attempting the repair.
Bill
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Samsung 61 inch DLP
Needs color wheel. What's the model #?
Oct 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Panasonic PT-47WX49 47" Rear Projection Television Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
