Question about Philips Magnavox 27MS343S 27" TV
Intermittent Defect on LCD TV
Approx 1 hr after switch on, the right side of screen flickers and shortly after this a vertical band of approx 5cm appears. The colour of this band varies with the dominant screen colour of the moment.Have had set with local engineers who found that on removal of back of set the problem does not appear, however on taking same home the problem reappears as above. The set is a Phillips 26" lcd PF9946
  • 1 more comment
  • comey34 Mar 13, 2008
    Thanks, but set is almost 3yrs old
  • BigRick56 Mar 30, 2008
    I'm having the same issue with my Philips 26" LCD tv. Any suggestions on what to do?
  • Anonymous Mar 16, 2014
    tv is switing off with a approx 2 cm dia colour dot above the screen center . suspecting this is happening during some voltage fluctuations . what may the issue
    Genius:
  • 1,153 Answers
If new, you should not remove anything, just send back to store or Manufacturer
Posted on Mar 13, 2008
How do I resolve a problem with a black vertical line that's appeared approx. 2 inches from the left side of the TV screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 27, 2015 | Emerson LC401EM2F 40" Inch LCD Full HD TV
Vertical Band has appeared on my TH-42PX60B
HI
Before getting a new tv set I would try all cables and contacts, as well as looking in the troubleshooting section in the manual.
hope you succeed
Kolbrun
Feb 20, 2012 | Panasonic VIERA Televison & Video
Display Issue, Hisense 42" LCD
Hello
Do a factory default reset to this set. You can get details about how to do this, from its user manual. If it does not help you, the t'Con bard [Timing Control Board] may need replacement.
The board sill look like this.
http://www.dataentryjobs.us/67948.html2_15_2012_7_21_33_am.jpg
Feb 14, 2012 | Televison & Video
Black vertical line of approx 1 mm from top to bottom of the screen at 80mm to the right of Samsung LCD TV LA40C630K1MXXs
I have hate to say it, but you need to replace your panel. Would be more cost effective to replace your set.
May 20, 2011 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
We have a Samsung 46" LCD HDTV and a red vertical band has shown up on the right side of the TV screen. Repair or bust?
If the band is there constantly and looking the same then the defect is in the LCD panel itself - the tv is gone.
Oct 10, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
Broad panel of strips (Vertical) down approx one third of tv
It can either be the LCD driver board or the worst case, LCD panel.
Nov 17, 2009 | Televison & Video
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Philips Magnavox 27MS343S 27" TV Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
