Question about Motorola Mobility Moto Q
Discharging itself on its own
It discharges itself on its own. I charge it fully before i go to bed. then the following morning, the phone is very warm and the screen is frozen. and then i turn it off and on. when it comes back on, the battery's almost completely drained.
    Problem Solver:
  • 13 Answers
Turn off Bluetooth, if you have a email client change how often you get the mail to manual.
Active Sync->Menu->Schedule->
Change the Peak Times....and the Off-Peak times to manual for best. Otherwised try every 2 hours or something like that to start with.
Posted on Apr 11, 2008
6ya staff
SOURCE:
Battery life draining overnight
Try disabling everything you can through the software, if not possible, unplug them. Then plug one in at a time and leave it overnight. If its OK in the morning, plug in the next item, and so on. Make sure battery is fully charged between each test. When the unit discharges overnight again, the last item you reconnected befroe it discharged is the one causing the voltage drain.
Aug 20, 2014 | Toshiba NB520 Netbook
Battery will charge to full then discharge without charging again
I am not an expert but I would try completely powering off my device before charging. There might be apps that are running in the background causing the battery to drain once again after fully charging it.
I hope this helps.
Sep 17, 2017 | HTC One V Android Unlocked Quad Band Gsm...
My Iphone 3g wont hole a charge for any amount of time. I charged it for most of the night last night and it was fully charged at 7 this morning now a 9 it is almost dead
Your battery is deteriorating. Send it in to apple to get it replaced-
$40- 50. when back, fully charge and discharge 5-10 times, and do NOt leave it constantly plugged in.
Jul 15, 2009 | Apple iPhone 3G
Battrey fast discharges
dear, there are two possible reasons of battery down.. 1st is that your battery is not ok and the other is your phone's charging IC is going to drain it.. so check the battery with other set or try with new battery in your phone.. regards, hope it will fix the issue so dont forget to rate it...
Jun 04, 2009 | Samsung Cell Phones
I havnt used nokia 6300 for 3 months , how to recharge battery
Because it has fully discharged, the battery has to be replaced. Try replacing the battery.
Rate this.
Apr 29, 2009 | Nokia 6300 Cellular Phone
Binatone Cordless Phone (2nd set) loses charge quickly
The batteries that are in most cordless phones, and even cell phones, have a "memory". If the battery is constantly being fully discharged from a lack of charging, or if it's used to being on the charger all the time, it will reduce the life of the battery substantially. You'll need to get a new battery, and try to make sure that the phone is placed back on its charger every night before you go to bed. This should allow the battery to receive a full charge each night to prevent full discharge and lengthen the life of your battery. I went through about 2 or 3 batteries once before I found this out. I'm sure that you'll find this helpful and it should save you a few bucks in not having to replace your battery as often. Please rate me accordingly, if it's not too much of a bother. Thanks and have a nice morning!
James
Nov 24, 2008 | Uniden Cordless Phone
LG VX5400 cell phone power problem
try replacing your battery
Jul 29, 2008 | Cell Phones
Battery
Before you change the battery:
  1. Charge the battery fully
  2. Discharge the battery fully
  3. Repeat steps 1 and 2
If the battery does not reset itself and start lasting longer then you do need to replace it.
Jun 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Rapid battery discharge/non connecting calls
take the phone and have it either reflash or the main-board replaced.
May 22, 2008 | LG CU400 Cellular Phone
Phone is discharging battery
I assume you mean the phone is discharging it quickly, probably not capabale of holding a long charge anymore, you can get batteries here - Panasonic KX-TG2422 battery
Oct 30, 2007 | Panasonic KX-TG2422W Cordless Phone...
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
56 people viewed this question
Top Motorola Mobility Computers & Internet Experts
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
JessicaChane2345
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
