Question about Fujitsu fi-5750C Flatbed Scanner
Fi 5750c adf will not initialise
Having a problem with a new Fujitsu fi 5750c. The adf stopped working without ever being in production. Now fujitsu will not help because it only has a 3 month warrentie.
Problem - adf almost dead
When I open the adf compartment, the bars will light up. When I close it, the paper pull innitialises, then thats it. It will not pull from the ADF. It has been hard tested wil the power on self test to test the speed of the adf. This does not work simply moves the light bar on the the flatbed.
This was tested in a standalone environment without the kofax card with the cofax card usb plugged in scssi plugged in and with nothing plugged in fully standalone.
I have logic tested the paper in sensor, paper detect sencer, and the paper out sencer. All are ok. I opened and checked for fuses, non existant. No electric burn that I can see or smell in main unit or adf. Unit was plugged into a surge strip during a lightening storm that spiked several server UPS batteries but I can find no damage to the unit. Flatbed works perfectly.
Unit also had the new firmware installed to the kofax card b fujitsu. I cannot be sure that it worked after that.
Any help would be appreciated
  • eccflash Mar 14, 2008
    Thanks but the ADF actually wont initialise. It's not a feeding problem. I also found today that if I put a paper halfway through the ADF then close it, it will eject the paper so the sencors are definatly working. I starting to believe that it is a problem with the firmware. It seems that the main unit does not see the adf peice. I cannot find a place to reinstall the firmware. Im thinking that the firmware update to the kofax card screwed something up.
  • 25 Answers
Just something simple to try...check your software setting to see if it is set for ADF or Flatbed feeding. You said the light bar moves when power is interupted or the adf opened. But you never said if it is scanning in Flatbed mode. If the Flatbed scans, then check the software setting. Most of the flatbed/adf hybrid scanners start up defaulted to flatbed, so when you try to scan, the adf won't pull anything thru until you change to ADF mode.
Posted on Jul 15, 2008
  • 490 Answers
Clean the rubber rollers in the ADF with a well wrung cloth thoroughly. Use IPA (Isopropyl Alcohol) if reqd. Dont use any other solvents.
S. Mohan
Posted on Mar 14, 2008
  • Mohan Sriraman
    Mohan Sriraman Mar 14, 2008
    It is very unlikely that the firmware is corrupted. There are sensors for paper beginning and ending. Sometimes a small piece of paper stuck to the sensor can create problem! Is the belt or motor for ADF okay?
    S. Mohan
How many lamps are in fujitsu 5750c scanner? how can i replace them?
Hi Albert,
There are two CCD lamps inside Fujitsu fi-5750c Duplex scanner.One is ADF Front and the other is ADF Back.To replace them, you may need the help of Fujitsu certified technician, for the procedure requires technical expertise.
Thanks & regards,
ScanCare
Nov 08, 2011 | Fujitsu fi-5750C Flatbed Scanner
Hi, I want to install both fujitsu fi 5750c and 5530C2 Scanners in same PC. OS is win XP. I tried through setup, but when one is installed, second one's setup says already having Scanner Utility...
There is no need of installing driver for fi-5530c2 scanner as the driver comes bendled in the fi-5750c scanner. Hence, please install the driver for fi-5750c.On the application, you need to chnage the scanner model under "Select Scanner" menu.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 27, 2011 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
Apr 30, 2010 | Fujitsu fi-5750C Flatbed Scanner
Is there a firmware update for this scanner, the
Thank you for contacting Fixya.
Firmware update for your Fujitsu Fi-5750C scanner is available. However, this may not be available to download.Hence, you need to contact Fujitsu Technical Support for the same.
Regards,
TechSatya
Jan 27, 2010 | Fujitsu fi-5750C Flatbed Scanner
Fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Jun 26, 2009 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-4340C changing the bulb
Open up the ADF ****.
Remove Two Silver screws holding front
of top cover.
Remove screw from ADF release button.
Pull back of top cover to unclip.
This will enable you to see the rear lamp bay
and camera unit.
Lamp is situated under Camera unit.
ADF = Auto Doc Feeder.
Jun 09, 2009 | Fujitsu fi-5750C Flatbed Scanner
ADF rotate
Remove the 2 thumbscrews fixing the ADF in place. These are found on the underside of the flatbed cover. Look at your "Getting Started" guide book for a picture. Slide the ADF to the middle of the scanner, then rotate it counter-clockwise.
Feb 16, 2009 | Fujitsu fi-5750C Flatbed Scanner
How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Oct 27, 2008 | Fujitsu fi-5750C Flatbed Scanner
Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750C Flatbed Scanner Logo
408 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
