Question about Pentax ME Super 35mm SLR Camera
SHUTTER HESITATION I had my Pentax Me Super "tuned up" along with replacement of the mirror cushions. The problem now is that the shutter seems to hesitate and doesn't seem to be working correctly at the faster shutter speeds.
    Scholar:
  • 85 Answers
May be the problem is with the lens. Put a maximum aperture say f 22 then press the shutter, if the leaves of the diaphragm shuts and opens fast ten your lens is OK
.If there is any oily appearance between the leaves of the diaphragm then it should be cleaned.
Posted on Apr 02, 2008
Mirror is locked open
Unless you have experience repairing cameras, this is not a DIY fix. Take your camera to a reputable camera shop and have a trained professional look at it.
Feb 03, 2012 | Pentax ME Super 35mm SLR Camera
Is my ME Super toast?
It doesn't need batteries to shoot. You can use it on manual without batteries, but the exposure meter won't work (if you know what you're doing you can go by). But the stuck mirror should be fixed. It could be just plain dirty/rusty/bent etc.
The advance lever might be gone since it won't 'click'. A professional shop can fix it, but the one you tried doesn't sound very professional...
Jun 09, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super: Mirror sticks in DOWN Position
The shutter & mirror is in need of a CLA. Clean, Lube & Ajustment. Its well needed for any camera when they are 20 years old and older
Feb 19, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button won't release
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/www.mypentax.com for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
Nov 23, 2008 | Pentax ME Super 35mm SLR Camera
After advancing the film, most times the shutter does not triggers.
Yes, I solved the problem. Apparently the problem was cused by grease aging in the mirror box due to the fact that de camera had not been used for a long time. I alternatively advanced the wind lever an depressed the shutter several times and now the camera is working ok. Regards,
Oct 11, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Seems to alway be in bulb mode.
Hello igby Slocumb,   As I recall, this was Pentax's way of mating electronics with mechanical cameras and the success rate was quite good. The only problem with the Pentax Super Program was the rather complex electronic circuit board. Your canera could have bad batteries, or batteries with too low amperage therefore no electronic shutter, have a short in the wiring, etc. You would need to do a shutter circuit check using a benchtop AC/DC power supply to exclude the batteries. Wow - really expensive and time-consuming = complete stripdown and repair. The camera is over approximately 30 years old making it a classic. It is no longer in production meaning parts need to be cannabalized from another old non-working Pentax Super Program. The cost of repair would exceed the value of the camera. Look for another good used model or move on to a Pentax DSLR (digital SLR) camera as your tool. Sorry I couldn't give you a better answer on how to fix your problem.
Jul 03, 2008 | Pentax ME Super 35mm SLR Camera
Wind up film button
This is a common problem with the older Pentax SLRs : shutter / mirror box needs servicing . The problem is caused by perished rubber parts. Although the problem is easy to fix, it has to be carried out by a pro because the mirror box has to be removed from the camera so that one can have access to the shutter and the side of the m-box where the problem is. Costs ? +- $150.
Nov 04, 2007 | Pentax ME Super 35mm SLR Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Major Pentax ME Super 35mm SLR Camera Problem!!!
The mirror box control mechanism needs servicing ( rubber parts have perished and are gumming up the workings of the mirror mechanism so shutter is not workingrking) . Unfortunatelly this requires complete strip down and so should be done professionally.
Aug 21, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
88 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
