Question about Ovens
What coloured wires go where on the main oven thermostat
Indesit double oven kd6c7ew
  • Anonymous Mar 20, 2014
    Fitted new thermostat, may have fitted wires in wrong place
  • 552 Answers
If you are speaking of the 240v connection to hook up the oven to the electrical source, then white is the neutral(white to white), black is one of the 240v hot wires(black to black), and red is the other 240v hot wire(red to red).
Finally there is a bare or green color ground wire that goes to the bare or green wire form your source.
normally, the two outside wires on a terminal strip are the hot wires and the middle onif the neutral(white). It does not matter which wire(red or black) goes to what hot terminal at the appliance.
If you are talking about the internal wiring, I can get you a schematic of that.
Posted on Mar 13, 2008
Our Neff U1421 double oven has a problem with tripping the main fuse when the main oven reaches 180 degrees. The oven is in manual mode not using the clock timer, can you throw any light on the proble
yes i know exactly whats wrong, one of your high accuracy temp sensors will have gone.
these tell the thermo what the sides & top of the oven temp is.
unscrew the oven from the base unit & pull it out, take the top off & you'll see them little round cylinder looking things with 2 wires coming off them(see link for pic) there screwed to the shell. the one that will have gone will no doubt have burn wires, or connections.
their sometimes called temp switch sensors
http://www.bi-metal-thermostat.com/photo/pl1619154-ip00_ceramic_bi_metal_thermostat_temperature_controller_for_micro_wave_oven.jpg
Sep 29, 2014 | Neff U1421 Double circotherm Electric Oven
Hi, I have a Neff Double Oven (U1721N0GB/02). In the process of replacing the main oven element (which was clearly visibly faulty) I think I may have casued a short-sircuit / blown an in-line fuse. I have...
Did you replace the element from inside the oven cavity? If so, you may have knock off one of the spade connections whilst pulling the bracket through. Isolate from mains, remove back panel behind oven (not in the cavity) and check you don't have a wire floating about. The wires usually look quite similar but if you look closing they should have a black or red fleck in them, the element has two prongs on each side, you need to put the two the same colour on one side and the other single different colour on the other prong. If the fan is working then you have not blown the limiter that you will see quite close to the fan, but you might have blown the thermostat or the selector switch. If the red light comes on the fascia when you select the temp then it's pretty safe to assume the thermostat is ok. Hope this helps
Mar 24, 2013 | Neff U1721 Double circotherm Electric Oven
The main oven gets warm but nowhere near hot enough to cook anything. Could it be the element? And if I replace it myself, what is the pen like object attached to a wire at the rear of the oven? Many...
if it gets hot but not hot enough its proberly your thermostat and the pen like thing over the wire is just a cover to insolate the bear spade connection
Aug 11, 2011 | Zanussi ZHQ575 Electric Double Oven
Temperature fluxuates constently on our double
The problem is obviously due to a faulty thermostat.
It could be the main oven stat, or an external thermostat that is the cause of the trouble.
Jan 18, 2010 | Bosch HBL 455 Stainless Steel Electric...
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
Indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Oct 23, 2009 | Ovens
Wattage for double oven
im getting a indesit fid201 double oven does it have to be hard wired or can it go on a 13amp plug
Feb 14, 2008 | Ovens
Lower oven not heating up properly
Go to Lakeland and buy the oven thermometer and the oven cleaner - the one that you brush on. Clean the thermostat sensor located at the top right rear of the oven - it should be bright chrome in colour. Ne need to take it out just brush the cleaner on to remove all the garbage on it, it may take several coats being careful not to damage the thin wire that comes from it. Once this is clean run the oven with the Lakeland thermometer and see how far it is out. Even at 20 degrees this may be acceptable to you as you can make allowances when using it. At least you will know what is going on to make an informed decision of whether of not to buy a new thermostat.
Dec 24, 2007 | Stoves 720EF Electric Double Oven
Ovens Logo
375 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
