Question about RCA RT2250 System
My rt2280 my system keeps shuting down it will play for a few minutes then shuts off and it will play a few minutes then totally shut down no standby light nothing
The quick answer is turn it off from the power button, then press the dvd button or whatever button you are using.Do it twice if it needs it.
Posted on Mar 13, 2008
SOURCE:
My rome total war game keeps shuting down every few minutes, what is wrong?
Sounds like a bad graphics card in the computer. Verify that the fan on the graphics card is actually turning, it may be heating up and shutting down.
Jul 26, 2014 | Activision Rome: Total War for Windows
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
My reciver keeps shuting off and saying protect when nothing conected to the reciver and it was playing music perfectly at low volume setting and then cut off
The Amplifier has a Fault and is shutting down to protect itself. Repeated cycling of this will cause a total failure in the Amplifier.
If you haven't got the Technical ability to have a look at it yourself then I suggest you take it to a service engineer or wait for a total failure and scrap it.
Jun 04, 2011 | Sony STR-DG520 Receiver
HI I have a new View Sonic DLP PJD 6221 It does not have very many hours, It turns on normally, after three to four minutes, it blinks for a few seconds and then shuts down. The red lamp light...
is the filter timer enabled. what are the total filter hours it has recorded.
is the air filter and vents clean etc.
it seems to be getting too hot as you suggest
Apr 20, 2011 | ViewSonic Office Equipment & Supplies
I just replaced altnator,car ran fine for 3 days now it keeps running down and shuting off after about15 min.alt light is not on and it jumps quick.could it be the batt?
You need to have the charging system tested.
The fact that the engine shuts down after a few minutes indicates that the alternator is not working. Once the engine is started, the alternator should provide sufficient electrical output to run everything in the vehicle except the starter. If the engine shuts down because of a lack of electrical power, you have an alternator problem; either internal or the wiring.
Feb 06, 2011 | 1988 Oldsmobile Cutlass Supreme
TV shuts down after a few seconds no picture comes on
I have LCD AKAI TV , It shuted down and no picture . Power never changes from red to green when I press remote control or standby button.
Oct 03, 2009 | Sanyo DP50747 50 in. Plasma TV
Red screen and lines, then TV shuts off automatically
Adjust RED screen drive down, or disconnect,unplug CRT board from red tube turn set back on if it plays without shuting off RED tube is shorted or video IC on CRT board is bad.
Jun 19, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
How do I shut off my zune!?!?
hi,
keep pressing the play button for 10seconds. it must shut off.
thanks you
Feb 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
Rt2280 no power up, no display, standby light works
Might be the relay on the power board that stands up just behind the big transformer. I has a complete no power also, I shorted out the relay legs on the black one, it started to work again. I will probably replace it, since the problem started by the system shutting off randomly.
Oct 19, 2008 | RCA RT2280 System
Mt rt2280
I think I answered the previous problem for 8 Mar.
Mar 13, 2008 | RCA RT2250 System
RCA RT2250 System Logo
176 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
