Question about Sharp AR-M162 All-In-One Laser Printer
"maintenance needed" after so many copies
I own a Sharp AR-M162 All-In-One Laser Printer ... Is there a way to by-pass the 50,000 copy maintenance? It locks up the machine and won't let you print anymore ... it is an expensive service to have done every 50,000 copies ($329.00) ...
    New Friend:
  • 91 Answers
To reset/unlock the machine, follow these steps :
1. Press : # *C * 20 START 1 START/OK
It's not only meant that the machine needs maintenance but it also needs a replacement of the consumable parts ( drum, cleaning blade and developer ) but the factory setting usually set this function to disable stop function when machine reaches 50K copies.
If this solved your problem, don't forget to change the consumable parts to keep your copy/print quality to it's best.
Good luck
Posted on Mar 10, 2009
  • 23 Answers
Change the paper orientation on your printer preference box to 8 x 11 not 8 x11 R
Posted on Oct 30, 2008
  • Vito Suglio Oct 30, 2008
    lets see 329 divided by 50,000 thats .00658 cents per copy, a little over 1/2 cent you are being cheap
    a little more that 1/2 cent a copy , you are being cheap.
    do you change your oil in your car when it stops running?
    It called preventative maintenace. Go to chijna and buy another machine!
I hate this machine. Right now I can't print. It tells me to change the tray when I try to print.
Posted on Mar 14, 2008
SOURCE:
There is an error symbol of a little man......what does that mean
If the machine is running it just means its due for maintenance.
May 04, 2015 | Sharp AR-M162 All-In-One Laser Printer
Sharp AR-m162 is printing from my computer but refuses to scan to the computer. It worked fine yesterday.
Run Sharpdesk network scan tool. in low right of your taskbar click on network scan tool
create a profile in profile tab, This will show up on sharp display as an avaiable location to scan to.you can choose where to scan to and what program if any to open when recieving a scan. Next in scanners tab click "auto detect" it will find available sharp scanners on the network. check one you want to use in the box in the list click "ok" close it make sure it is running in the task bar and add it to startup if need be but you should be good to go after this
David
Nov 13, 2017 | Sharp AR-M162 All-In-One Laser Printer
Code F2-04 solution
http://www.retrevo.com/support/Sharp-AR-M162-Multifunction-Printers-manual/id/600ag113/t/2/
Above is your user manual below is your service manual.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=AR-162,+AR-163,+AR-201,+AR-206,+AR-207,+AR-F201
http://www.eserviceinfo.com/fulltext.php?search_ft=DPX-7010MD
You have a sensor error. I have included your user and service manuals so you can attend to the error.
F1-04 Bin limit position sensor error in sorter
Aug 12, 2010 | Sharp AR-M162 All-In-One Laser Printer
Create fax from my HP window vista computer to Sharp AR-M162
Won't work with Vista unless you spend $100 for some fax program
Feb 20, 2009 | Sharp AR-M162 All-In-One Laser Printer
Wireless
Check that the wap key corresponds with your wireless network also install printer as network pinter with a ip address also you nay have to add a new port i.e. wireless port. try these.
Thanks J
Jan 15, 2008 | Sharp AR-M162 All-In-One Laser Printer
Sharp AR-M162 All-In-One Laser Printer Logo
325 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
