Question about Mitsubishi WS-65513 65" Rear Projection HDTV
No sound with HDMI to DVI connection
Just upgraded my Dish to the VIP722 HDTV and bought a hdmi to dvi cable and hooked up. When I scroll the input to the 1080i setting the pic is there but no audio. Can someone let me know what the input settings should be and how to get the audio working? Thanks in advance.
Fred
  • wizardbee Mar 14, 2008
    Thanks Troy.....I'll just check to see where on the sat box it'll get connected to...hopefully no worries....
    Genius:
  • 1,153 Answers
HDMI are only for video, you would need separate audio cables.
Posted on Mar 13, 2008
SOURCE:
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Hp plasma ID5226N can get external audio input when in HDMI 2. I have a DVI to HDMI cable from my computer to TV, & manual says to hook the audio to the input jacks, but no sound comes out. I can use...
DVI cables are usually HDMI compatible. The downside is that DVI usually doesn't carry any audio. Your computer may need a specific audio card to transmit audio/video data from your DVI output to the HDMI input on the TV. You can find one at your local computer store and ask if it is compatible with your computer
I hope this helps...good luck
Jun 23, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
How do i connect advent pc to philips hdtv. do i need to change settings?
well not really, you need to buy the proper cable depending on the inputs of your tv, it may have the standar VGA connection as the standar pc monitor.
DVI to VGA cable
DVI to DVI
HDMI to DVI
HDMI to HDMI
after you have the proper cable just plug it, and turn it off, disconnect the standar computer minitor and turn it back on. the computer will set the input signal from the tv by itself.
thats for the video, for the audio you need a different cable
3.5 mm to RCA (white and red cable)
3.5 mm to 3.5mm headphonejack cable
but if you are using the HDMI to HDMI you don't need a sound cable.
Oct 07, 2009 | Computers & Internet
DVI-HDMI work but there is no sound
DVI input has no sound as normal you can use a RCA connection to get sound from the freeview box
Apr 21, 2017 | ViewSonic N3000W 30 in. HD-Ready LCD...
DVI-->HDMI cable causes tv speakers to hiss and pop
DVi to HDMI. ? hmmmmm
I recon you spend £49.99 and get a DVI & Audio to HDMI Converter. This will resolve the issue
Nov 26, 2008 | LG 42LG50 42 in. LCD HDTV
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Play station 3 hdmi-dvi
Yes you can. It will not be like a HDMI cable but it will be better than the RCA. Your image will be in your HDTV (1920 × 1080). But you will have to buy a HDMI cable and and HDMI-DVI adaptor. You will not have sound so you will have to connect either your RCA or if you have a Digital Optical Audio sounds better.
If you have any questions just ask.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Help with hook up
A lot of people buy digital TV's only to discover that they need to upgrade the rest of their stuff as well. You can hook up the dvr and vcr with composite or component cables of course, but that isn't digital.
Jan 24, 2008 | Haier HLH32ATBB 32 in. LCD HDTV
Hdmi to dvi
a DVI Connection does not transmit sound, so you will need a seperate audio cable. Have you changed the settings in the ps3 and your tv's input to HD signal or 720 DPI, do not choose 1080i or 1080P as DVI does not support those high settings.
Sep 05, 2007 | Sony Playstation 3 (PS3) Console
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
