Question about RCA RT2250 System
Mt rt2280 my system keeps shuting down it will play for a few minutes and then shut off it will work alittle the totally shut down no standby light nothing and won't come back at all
  • DaveLee243 Sep 14, 2008
    Mine will work for about 20 mins then shut on and off over and over. Now it doesnt work at all. has power fine to the unit but no sound at all
I think I answered the previous problem for 8 Mar.
Posted on Mar 13, 2008
My rome total war game keeps shuting down every few minutes, what is wrong?
Sounds like a bad graphics card in the computer. Verify that the fan on the graphics card is actually turning, it may be heating up and shutting down.
Jul 26, 2014 | Activision Rome: Total War for Windows
My reciver keeps shuting off and saying protect when nothing conected to the reciver and it was playing music perfectly at low volume setting and then cut off
The Amplifier has a Fault and is shutting down to protect itself. Repeated cycling of this will cause a total failure in the Amplifier.
If you haven't got the Technical ability to have a look at it yourself then I suggest you take it to a service engineer or wait for a total failure and scrap it.
Jun 04, 2011 | Sony STR-DG520 Receiver
HI I have a new View Sonic DLP PJD 6221 It does not have very many hours, It turns on normally, after three to four minutes, it blinks for a few seconds and then shuts down. The red lamp light...
is the filter timer enabled. what are the total filter hours it has recorded.
is the air filter and vents clean etc.
it seems to be getting too hot as you suggest
Apr 20, 2011 | ViewSonic Office Equipment & Supplies
I just replaced altnator,car ran fine for 3 days now it keeps running down and shuting off after about15 min.alt light is not on and it jumps quick.could it be the batt?
You need to have the charging system tested.
The fact that the engine shuts down after a few minutes indicates that the alternator is not working. Once the engine is started, the alternator should provide sufficient electrical output to run everything in the vehicle except the starter. If the engine shuts down because of a lack of electrical power, you have an alternator problem; either internal or the wiring.
Feb 06, 2011 | 1988 Oldsmobile Cutlass Supreme
TV shuts down after a few seconds no picture comes on
I have LCD AKAI TV , It shuted down and no picture . Power never changes from red to green when I press remote control or standby button.
Oct 03, 2009 | Sanyo DP50747 50 in. Plasma TV
I have an HP Pavillion dv9500 laptop. After shutting down, all the keyboard lights to the right of the power button stay lit. This shows the power is not shut off but should be. Any solutions?
First of all, is the laptop on charge? Usually when the laptop is on charge there is a light somewhere that remains on until it is charged. After charging, the light goes of and if the laptop is not used for a long time, the battery usually discharges a little and the system senses this and recharges it as top-up and the light comes on, then goes off once charged. If your laptop is not on charge, then there is 2 things that could be the cause. 1) It is not shut down properly (on stand-by). 2) It may be downloading updates and it would probably shut down later, depending on the size of the update, it may take a few minutes or up to 1 hour. If in 1 hour the light is still on, then there is a problem with the laptop and need to be checked by a professional, or, altermnatively, turn it off a second time and see if the light still remains on. Lastly, you did not state what kind of lights remain on, Power, Charging, Standby, etc. it is difficult to help you with your query as the problem could be the laptop itself. There are other things that could keep the laptop on, and that may be if your laptop is connected to a network. Regards.
Sep 27, 2009 | Computers & Internet
Red screen and lines, then TV shuts off automatically
Adjust RED screen drive down, or disconnect,unplug CRT board from red tube turn set back on if it plays without shuting off RED tube is shorted or video IC on CRT board is bad.
Jun 19, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Rt2280 no power up, no display, standby light works
Might be the relay on the power board that stands up just behind the big transformer. I has a complete no power also, I shorted out the relay legs on the black one, it started to work again. I will probably replace it, since the problem started by the system shutting off randomly.
Oct 19, 2008 | RCA RT2280 System
I upgraded the BIOS and now my Presario V4000 keeps shuting Down
Try a system restore. If that doesn't work download and revert back to the old bios.
Jun 20, 2008 | HP Compaq Presario V5000Z Notebook
My rt2280
the quick answer is turn it off from the power button, then press the dvd button or whatever button you are using.Do it twice if it needs it.
Mar 13, 2008 | RCA RT2250 System
RCA RT2250 System Logo
128 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
